IOPS
A generic benchmark orchestration framework for automated parametric experiments.
IOPS automates the generation, execution, and analysis of benchmark experiments. Instead of writing custom scripts for each study, you define a YAML configuration describing what to vary, what to run, and what to measure; IOPS handles the rest.
Without IOPS: Write bash scripts → Parse outputs → Aggregate data → Generate plots → Repeat for each parameter change
With IOPS: Write one YAML config → Run iops run config.yaml → Get interactive HTML reports
Originally designed for I/O performance studies (see our 2022 paper), IOPS has evolved into a generic framework for any parametric benchmark workflow.
Key Features
- Parameter Sweeping: Generate and execute tests for all parameter combinations
- Search Strategies: Exhaustive, Bayesian optimization, or random sampling
- Execution Backends: Run locally or submit to SLURM clusters
- Execution Exploration: Find and filter execution folders by parameter values
- Caching: Skip redundant tests with parameter-aware result caching
- Budget Control: Set core-hour limits to avoid exceeding compute allocations
- Reports: Interactive HTML reports with plots and statistical analysis
- Output: Export results to CSV, Parquet, or SQLite
Blog
Tutorials and use cases on the blog:
- Measuring the runtime overhead of an I/O interception library - Quantifying TOTO’s overhead with conditional variables and resource tracing
- Testing IOPS’s Bayesian search against random sampling - How guided search reaches the optimum with far fewer evaluations
- Using IOPS on Grid'5000 - Run IOPS with OAR scheduler on Grid'5000
Links
- Slides: IOPS overview (PDF) - YAML configuration, search strategies, parsers, and reports, with a running IOR example
- Repository: GitLab
- Issues: Issue Tracker
- PyPI: iops-benchmark
