This study is part of our paper “TOTO: Transparent I/O Tuning for HPC Applications”, accepted at ICS 2026 (International Conference on Supercomputing, Belfast, July 2026). The overhead measurements below were produced with IOPS.
When you intercept I/O system calls to analyze application behavior, how much overhead do you actually add? That’s the question we needed to answer for TOTO (Transparent and Online Tool for I/O), a library that hooks into I/O calls via LD_PRELOAD to provide runtime analysis of parallel file system access patterns.
Before deploying TOTO in production, we needed to quantify its overhead across different workloads. Sounds simple, but there were a few complications:
- Baseline comparison: Every test must run both with and without TOTO
- Multi-dimensional space: Overhead varies with process count, I/O size, access pattern, and TOTO’s analysis frequency
- Conditional parameters: TOTO-specific settings only make sense when TOTO is enabled
- Resource monitoring: We need CPU and memory data, not just execution time
This turned out to be a perfect use case for IOPS. Here’s how we tackled it.
The Key Tricks
Conditional Variables
TOTO has an analysis_period parameter that controls how often it gathers I/O statistics. But this parameter is meaningless when TOTO is disabled, so we’d just be creating redundant test combinations.
IOPS has a when clause for exactly this situation:
vars:
with_toto:
type: bool
sweep:
mode: list
values: [0, 1] # false, true
analysis_period:
type: int
sweep:
mode: list
values: [100, 250, 500, 1000, 2000]
when: "with_toto" # Only sweep when TOTO is enabled
default: 0 # Use 0 when TOTO is disabled
Without when, we’d have 2 × 5 = 10 combinations. With when, we get 5 (with TOTO) + 1 (baseline) = 6 combinations. The savings add up quickly when you have multiple conditional parameters.
Resource Tracing
Execution time alone doesn’t tell the whole story. We wanted CPU and memory utilization data to understand where the overhead comes from. IOPS can sample these during execution:
benchmark:
probes:
resource_sampling: true # Enable tracing
sampling_interval: 0.05 # Sample every 50ms
This generates per-node trace files with timestamped samples, plus a summary CSV with mean/max/std statistics. We can then compare resource footprints between baseline and instrumented runs directly.
Conditional Execution with Jinja2
Using Jinja2 conditionals in the script template, we can enable TOTO only when with_toto is true:
mpirun ... {% if with_toto %} env LD_PRELOAD=/path/to/toto.so {% endif %} {{ command.template }}
Results
To isolate the cost of the interception and analysis machinery, we ran TOTO with its stripe-count tuning disabled: every component stays active (calls are intercepted, statistics are kept, the analysis thread still communicates), but TOTO cannot improve performance, so only its negative impact shows up. We picked the largest-scale experiments on each platform (256 processes on PlaFRIM, 8192 on Irene), repeated each configuration 5 times, and swept request size (1, 8, 32 MiB), spatiality (contiguous, random), file strategy (shared-file, file-per-process), and the analysis period (250–2000 ms).
Bandwidth overhead on PlaFRIM
The heatmap below reports the bandwidth slowdown of TOTO versus the baseline, per access pattern and analysis period. Overhead is low in general (median 1%) and never exceeds 8%, staying below 5% for most cases. The worst case is random access to a shared file, where the slowdown reaches up to 8% for short analysis periods (250–500 ms): shorter periods mean more frequent analysis communication, the random pattern triggers more seek calls, and the shared file forces the master rank to combine per-process statistics. (Negative values are an artifact of run-to-run variability.)
At scale, overhead disappears into the noise (Irene)
On Irene, with 8192 processes, run-to-run variability dominates: the medians even suggest TOTO is faster in some cases. None of these differences are statistically significant (Mann-Whitney U test, 5% confidence), so we conclude the overhead is negligible at scale.
Where the cost comes from: CPU vs. the analysis period
Resource tracing tells us why. Peak memory per node sits on the diagonal (no measurable overhead), but average CPU usage is driven by the analysis period: at 250 ms the analysis thread communicates so often that CPU usage climbs from 5–8% to ~30%, while at 1000–2000 ms it falls back near the baseline. The analysis period is therefore a trade-off between adaptation speed and CPU cost, and a value of 500 ms or above keeps both performance and resource overhead low.
Full Configuration
Here’s the complete YAML configuration used in this study:
benchmark:
description: "TOTO Study: All tests with toto + baseline (without toto)"
workdir: "/home/user/workdir"
cache_file: "/home/user/workdir/cache.db"
repetitions: 6
search_method: "exhaustive"
executor: "slurm"
random_seed: 42
cache_exclude_vars: ["summary_file"]
cores_expr: "{{ nodes * 36 }}"
probes:
system_snapshot: true
execution_index: true
vars:
with_toto:
type: bool
sweep:
mode: list
values: [0, 1]
nodes:
type: int
sweep:
mode: list
values: [16]
total_procs:
type: int
sweep:
mode: list
values: [16, 64, 256]
requests_mb:
type: int
sweep:
mode: list
values: [1, 8, 32]
volume_size_gb:
type: int
sweep:
mode: list
values: [32]
analysis_period:
type: int
sweep:
mode: list
values: [250, 500, 1000, 2000]
when: "with_toto"
default: 0
spatiality:
type: str
sweep:
mode: list
values: ['cont', 'random']
filestrategy:
type: str
sweep:
mode: list
values: ['shared-file', 'file-per-proc']
procs_per_node:
type: int
expr: "{{ total_procs // nodes }}"
block_size_mb:
type: int
expr: "(volume_size_gb * 1024) // (nodes * procs_per_node)"
summary_file:
type: str
expr: "{{ execution_dir }}/summary_{{ execution_id }}_{{ repetition }}.json"
constraints:
- name: "block_transfer_alignment"
rule: "block_size_mb % requests_mb == 0"
violation_policy: "skip"
command:
template: >
ior -w -b {{ block_size_mb }}mb
-t {{ requests_mb }}mb
{% if spatiality == 'random' %} -z {% endif %}
{% if filestrategy == 'file-per-proc' %} -F {% endif %}
-O summaryFile={{ summary_file }} -O summaryFormat=JSON
-o /beegfs/user/ior/output.ior
metadata:
operation: "write"
scripts:
- name: "ior"
script_template: |
#!/bin/bash
#SBATCH --job-name=iops_{{ execution_id }}
#SBATCH --ntasks={{ total_procs }}
#SBATCH --nodes={{ nodes }}
#SBATCH --ntasks-per-node={{ procs_per_node }}
#SBATCH --time=00:01:00
#SBATCH --chdir={{ execution_dir }}
#SBATCH -o batch%j.out
#SBATCH -e batch%j.err
#SBATCH --exclusive
#SBATCH --constraint bora
{% if with_toto %}
export TOTO_PFS_PATHS=/beegfs
export TOTO_LOG_LEVEL='ERROR'
export TOTO_LOG_TO_STDOUT=0
export TOTO_BEEGFS_STRIPING_PREFIX=/beegfs/user
export TOTO_BEEGFS_STRIPING_SUFIX=ior
export TOTO_LOGS_FOLDER={{ execution_dir }}
export TOTO_ANALYSIS_PERIOD={{ analysis_period }}
{% endif %}
module purge
module load mpi/openmpi/4.0.1
module load compiler/gcc/12.2.0
mpirun --mca btl ^uct --mca fs ^lustre --mca osc ^ucx --mca pml ^ucx \
--mca btl_openib_allow_ib 1 \
{% if with_toto %} env LD_PRELOAD=/home/user/toto/toto.so {% endif %} \
parser:
file: "{{ summary_file }}"
metrics:
- name: bwMiB
- name: totalTime
parser_script: |
import json
def parse(file_path: str):
with open(file_path, "r") as f:
data = json.load(f)
tests = data.get("tests", [])
if not tests:
raise ValueError("No tests found in IOR JSON")
results = tests[0].get("Results", [])
if not results:
raise ValueError("No Results found in IOR JSON")
write_res = next(
(r for r in results if str(r.get("access", "")).lower() == "write"),
results[0],
return write_res
output:
sink:
type: csv
path: "{{ workdir }}/results.csv"
Related Documentation
- Full Interactive Report - Explore the complete results from this study
- Resource Tracing - CPU and memory monitoring
- Conditional Variables - How
whenclauses work - YAML Schema Reference - Complete configuration reference
- Execution Backends - SLURM and local execution
