Data Sources
This page documents where IOPS CLI commands read their data.
Overview
IOPS commands read from result files and from metadata files generated during execution. Metadata files have the __iops_ prefix and are documented in the Metadata Files user guide.
Data Sources by Command
iops find ◄─── __iops_index.json
          ◄─── __iops_status_rollup.json (preferred; falls back to per-folder scan)
          ◄─── __iops_status.json (fallback)
          ◄─── __iops_run_metadata.json (optional metadata)
iops find --watch ◄─── __iops_index.json (polling)
                  ◄─── __iops_status_rollup.json (preferred; polling)
                  ◄─── __iops_status.json (fallback scan)
iops report ◄─── __iops_run_metadata.json
            ◄─── results.csv/parquet/sqlite
Status roll-up fast path
Both iops find and watch mode read the run-root __iops_status_rollup.json aggregate instead of scanning every execution’s repetition folders, which keeps them responsive on large parameter spaces. The per-folder __iops_status.json files remain the source of truth (and the node-to-runner channel in single-allocation mode); the roll-up is an accelerator. Watch always prefers it; iops find only trusts it when the run marked it complete, otherwise it falls back to the folder scan. When the roll-up is absent (older runs, archives), both fall back automatically.
iops find
InformationSource FileLocationField(s)Notes
Benchmark name__iops_index.jsonRun rootbenchmark
Execution list__iops_index.jsonRun rootexecutionsDict keyed by exec_XXXX
Execution path__iops_index.jsonRun rootexecutions[key].pathRelative to run root
Parameters__iops_index.jsonRun rootexecutions[key].params
Command__iops_index.jsonRun rootexecutions[key].commandShown with --show-command
Execution status__iops_status.jsonexec_XXXX or repetition_NstatusAggregated from repetitions
Error message__iops_status.jsonexec_XXXX or repetition_Nerror
End time__iops_status.jsonexec_XXXX or repetition_Nend_time
Cache status__iops_status.jsonrepetition_NcachedTrue/False/“partial”
Skip reason__iops_status.jsonexec_XXXXreasonOnly for SKIPPED tests
Description__iops_run_metadata.jsonRun rootbenchmark.description
Hostname__iops_run_metadata.jsonRun rootbenchmark.hostname
Timestamp__iops_run_metadata.jsonRun rootbenchmark.timestamp
Single execution view (when pointing to exec_XXXX folder):
Parameters__iops_params.jsonexec_XXXXAll fields
iops find --watch
Watch mode is designed to work during execution, so it only reads from files that exist before the benchmark completes. It does not read from __iops_run_metadata.json (which is written at the end).
Total expected__iops_index.jsonRun roottotal_expectedTotal repetitions across all tests
Repetitions__iops_index.jsonRun rootrepetitionsPer-test repetition count
Folders upfront__iops_index.jsonRun rootfolders_upfrontTrue if folders created upfront
Active tests__iops_index.jsonRun rootactive_testsTests that will execute
Skipped tests__iops_index.jsonRun rootskipped_testsTests skipped by constraints
Test status (upfront)__iops_index.jsonRun rootexecutions[key].statusOnly in upfront mode
Skip reason (upfront)__iops_index.jsonRun rootexecutions[key].skip_reasonOnly in upfront mode
Repetition status__iops_status.jsonrepetition_NstatusPer-repetition status
Duration__iops_status.jsonrepetition_Nduration_secondsActual execution time
Error message__iops_status.jsonrepetition_Nerror
Metrics__iops_status.jsonrepetition_NmetricsDict of metric values (with –metrics flag)
Skip reason__iops_status.jsonexec_XXXXreasonFor SKIPPED tests
iops report
The report command reads from the run metadata file and the results output file. It does not read from index or status files.
IOPS version__iops_run_metadata.jsonRun rootiops_versionFor compatibility check
Benchmark config__iops_run_metadata.jsonRun rootbenchmark.*Name, description, executor, etc.
Variables config__iops_run_metadata.jsonRun rootvariablesVariable definitions and sweep info
Metrics config__iops_run_metadata.jsonRun rootmetricsMetric names and parser info
Output config__iops_run_metadata.jsonRun rootoutputPath and type of results file
Reporting config__iops_run_metadata.jsonRun rootreportingPlot configs, sections, theme
System environment__iops_run_metadata.jsonRun rootsystem_environmentCPU, memory, hostname, etc.
Planner stats__iops_run_metadata.jsonRun rootbenchmark.planner_statsTotal/active/skipped combinations
Results dataResults fileoutput.pathAll columnsCSV, Parquet, or SQLite
Execution statusResults fileoutput.pathmetadata.__executor_statusFilters to SUCCEEDED only
DurationResults fileoutput.pathmetadata.__sysinfo.duration_secondsFor runtime calculations
TimestampsResults fileoutput.pathmetadata.__job_start, metadata.__submission_time, metadata.__endFallback for duration
Results file types:
TypeRead MethodNotes
CSVpd.read_csv()Default format
Parquetpd.read_parquet()Requires pyarrow
SQLitepd.read_sql_query()Reads from output.table
File Locations
workdir/
  run_001/                              # Run root
    __iops_index.json                   # Index file (find, watch)
    __iops_run_metadata.json            # Run metadata (find, report)
    results.csv                         # Results file (report)
    exec_0001/                          # Execution folder
      __iops_params.json                # Parameter values (find single)
      __iops_status.json                # Test-level status (SKIPPED only)
      repetition_1/
        __iops_status.json              # Repetition status (find, watch)
        __iops_sysinfo.json             # System info (stored in results)
      repetition_2/
    exec_0002/
Source Code References
ModuleFilePurpose
findiops/results/find.pyStatic execution listing
watchiops/results/watch.pyLive execution monitoring
reportiops/reporting/report_generator.pyHTML report generation
Key Functions
find.py:
  • find_executions() - Main entry point
  • _read_status() - Reads and aggregates status from status files
  • _read_run_metadata() - Reads run metadata file
  • _show_executions_from_index() - Displays execution table
watch.py:
  • watch_executions() - Main entry point with live updates
  • _load_index() - Loads index file with execution metadata
  • _collect_execution_data() - Collects current status from all executions
  • _build_table() - Builds Rich table for display
  • _build_progress_bar() - Builds progress bar with status counts
report_generator.py:
  • ReportGenerator.__init__() - Initializes with workdir path
  • load_metadata() - Loads __iops_run_metadata.json
  • load_results() - Loads results from CSV/Parquet/SQLite
  • generate_report() - Generates HTML report
Data Flow Diagrams
During Execution
Runner
  ├──► __iops_index.json (updated incrementally)
  ├──► exec_XXXX/
  │      ├──► __iops_params.json (before test)
  │      └──► __iops_status.json (if SKIPPED)
  └──► exec_XXXX/repetition_N/
         ├──► __iops_status.json (after completion)
         └──► __iops_sysinfo.json (via probe script)
After Execution
Runner
  ├──► __iops_run_metadata.json (at end)
  └──► results.csv (incrementally during execution)
