Execution Loop
This page documents the IOPS execution loop architecture: how the Runner, Planner, and Executor components orchestrate benchmark execution.
Overview
The execution loop follows a pull-based design where the Runner requests tests from the Planner and delegates execution to the Executor:
│                         IOPSRunner                              │
│  │   Planner   │─────►│   Runner    │─────►│  Executor   │     │
│  │             │      │   Loop      │      │             │     │
│  │ next_test() │      │             │      │ submit()    │     │
│  │             │◄─────│             │◄─────│ wait_and_   │     │
│  │ record_     │      │             │      │ collect()   │     │
│  │ completed() │      │             │      │             │     │
│  │   Matrix    │      │   Cache     │      │   Parser    │     │
│  │  Builder    │      │             │      │             │     │
Component Roles
ComponentResponsibility
RunnerOrchestrates the execution loop, manages cache, tracks budget, writes results
PlannerGenerates test configurations, manages execution order, prepares artifacts
ExecutorSubmits jobs, waits for completion, collects output and metrics
Matrix BuilderGenerates parameter combinations from config, applies constraints
CacheStores/retrieves results to skip redundant executions
ParserExtracts metrics from benchmark output files
The Execution Loop
Main Loop (IOPSRunner.run())
def run(self):
    while True:
        # 1. Check budget
        if budget_exceeded:
            break
        # 2. Get next test from planner
        test = self.planner.next_test()
        if test is None:
            break  # No more tests
        # 3. Check cache
        if self.cache and self.use_cache_reads:
            cached_result = self.cache.get_cached_result(test.vars, test.repetition)
            if cached_result:
                # Use cached result, skip execution
                test.metadata.update(cached_result)
                test.metadata['__cached'] = True
        # 4. Execute if not cached
        if not used_cache:
            self._write_status_file(test, status="RUNNING")
            self.executor.submit(test)
            self.executor.wait_and_collect(test)
            # Store in cache if succeeded
            if succeeded:
                self.cache.store_result(...)
        # 5. Write status and results
        self._write_status_file(test)
        save_test_execution(test)
        # 6. Notify planner of completion
        self.planner.record_completed_test(test)
Sequence Diagram
Runner              Planner             Executor            Cache
  │  next_test()       │                    │                 │
  │  ExecutionInstance │                    │                 │
  │  get_cached_result()                    │                 │
  │  (cache miss)      │                    │                 │
  │  submit(test)      │                    │                 │
  │  wait_and_collect(test)                 │                 │
  │  test.metadata updated                  │                 │
  │  store_result()    │                    │                 │
  │  record_completed_test()                │                 │
Planner Architecture
Base Planner
All planners inherit from BasePlanner and implement:
class BasePlanner(ABC):
    @abstractmethod
    def next_test(self) -> Optional[ExecutionInstance]:
        """Return next test to execute, or None when done."""
        pass
    @abstractmethod
    def record_completed_test(self, test: ExecutionInstance) -> None:
        """Called after each test completes (for adaptive planners)."""
        pass
    def _prepare_execution_artifacts(self, test, repetition):
        """Create folders and scripts for execution."""
        pass
Registry Pattern
Planners (and executors, see below) register themselves with a decorator:
@BasePlanner.register("exhaustive")
class ExhaustivePlanner(BasePlanner):
@BasePlanner.register("random")
class RandomSamplingPlanner(BasePlanner):
@BasePlanner.register("bayesian")
class BayesianPlanner(BasePlanner):
@BasePlanner.register("adaptive")
class AdaptivePlanner(BasePlanner):
# Dynamic instantiation from config
planner = BasePlanner.build(cfg)  # Uses cfg.benchmark.search_method
Planner Types
PlannerStrategyrecord_completed_test()
ExhaustiveTests all parameter combinationsNo-op
RandomRandom subset of parameter spaceNo-op
BayesianOptimization-guided searchUpdates surrogate model
AdaptiveThreshold probingEvaluates stop_when, advances or stops the probe
Execution Matrix
The planner builds an execution matrix from config:
def _build_execution_matrix(self):
    # Build parameter combinations
    kept_instances, skipped_instances = build_execution_matrix(self.cfg)
    # Store skipped for reference
    self.skipped_matrix = skipped_instances
    # Shuffle for random execution order
    self.execution_matrix = self.random_sample(kept_instances)
    # Initialize folders upfront if configured
    if cfg.benchmark.create_folders_upfront:
        self._initialize_all_folders(kept_instances, skipped_instances)
Repetition Interleaving
The ExhaustivePlanner uses random interleaving to avoid running all repetitions of one test before moving to the next:
def next_test(self):
    # Randomly pick from active tests (those with remaining repetitions)
    idx = self.random.choice(self._active_indices)
    test = self.execution_matrix[idx]
    # Track which repetition this is
    rep_idx = self._next_rep_by_idx[idx]
    self._next_rep_by_idx[idx] += 1
    # Remove from active pool when all reps done
    if self._next_rep_by_idx[idx] >= self._total_reps_by_idx[idx]:
        self._active_indices.remove(idx)
    # Prepare artifacts for this repetition
    self._prepare_execution_artifacts(test, repetition=rep_idx + 1)
    return test
Executor Architecture
Base Executor
All executors inherit from BaseExecutor and implement:
class BaseExecutor(ABC):
    # Status constants
    STATUS_SUCCEEDED = "SUCCEEDED"
    STATUS_FAILED = "FAILED"
    STATUS_RUNNING = "RUNNING"
    STATUS_PENDING = "PENDING"
    STATUS_ERROR = "ERROR"
    @abstractmethod
    def submit(self, test: ExecutionInstance):
        """Submit/execute the job. Sets test.metadata["__jobid"]."""
        pass
    @abstractmethod
    def wait_and_collect(self, test: ExecutionInstance):
        """Wait for completion, parse metrics, collect sysinfo."""
        pass
Registry Pattern
@BaseExecutor.register("local")
class LocalExecutor(BaseExecutor):
@BaseExecutor.register("slurm")
class SlurmExecutor(BaseExecutor):
executor = BaseExecutor.build(cfg)  # Uses cfg.benchmark.executor
LocalExecutor
Runs benchmarks via subprocess:
def submit(self, test):
    self._init_execution_metadata(test)
    now = timestamp
    test.metadata["__submission_time"] = now
    test.metadata["__job_start"] = now  # No queue for local
    result = subprocess.run(
        ["bash", str(test.script_file)],
        cwd=test.execution_dir,
        capture_output=True,
    test.metadata["__end"] = timestamp
    # Write stdout/stderr to files
    stdout_path.write_text(result.stdout)
    stderr_path.write_text(result.stderr)
    # Set status based on return code
    if result.returncode != 0:
        test.metadata["__executor_status"] = self.STATUS_FAILED
    else:
        test.metadata["__executor_status"] = self.STATUS_SUCCEEDED
def wait_and_collect(self, test):
    # Parse metrics if succeeded
    if test.metadata["__executor_status"] == self.STATUS_SUCCEEDED:
        metrics = parse_metrics_from_execution(test)
        test.metadata["metrics"] = metrics
    # Collect system info from probe
    self._store_system_info(test)
SlurmExecutor
Submits to SLURM and polls for completion:
    # Submit via sbatch
    result = subprocess.run(submit_cmd, capture_output=True)
    job_id = parse_job_id(result.stdout)
    test.metadata["__jobid"] = job_id
    test.metadata["__submission_time"] = timestamp
    # Track for cleanup on interrupt
    if self.runner:
        self.runner.submitted_job_ids.add(job_id)
    job_id = test.metadata["__jobid"]
    # Poll until job leaves queue
    while True:
        state = get_job_state(job_id)
        if state == "RUNNING" and not test.metadata.get("__job_start"):
            test.metadata["__job_start"] = timestamp  # Job started running
        if state not in SLURM_ACTIVE_STATES:
            break
        time.sleep(poll_interval)
    # Determine final status
    if state in SLURM_FAIL_STATES:
    else:
    # Parse metrics and collect sysinfo
    if succeeded:
ExecutionInstance
The central data structure passed through the loop:
@dataclass
class ExecutionInstance:
    # Identity
    execution_id: int           # Unique ID within run
    repetition: int             # Current repetition (1-based)
    repetitions: int            # Total repetitions
    # Parameters
    vars: Dict[str, Any]        # Resolved variable values
    command: str                # Rendered command template
    # Paths
    script_file: Path           # Path to generated script
    execution_dir: Path         # Working directory
    post_script_file: Path      # Optional post-processing script
    # Parser config
    parser: ParserConfig        # Metrics extraction config
    # Metadata (populated during execution)
    metadata: Dict[str, Any]    # Status, timing, metrics, sysinfo
Metadata Keys
KeySet ByDescription
__jobidExecutorJob identifier (e.g., SLURM job ID)
__submission_timeExecutorTime when job was submitted
__job_startExecutorTime when job started running (after queue wait)
__endExecutorExecution end timestamp
__executor_statusExecutorFinal status (SUCCEEDED, FAILED, etc.)
__errorExecutorError message if failed
__returncodeExecutorScript exit code
__stdout_pathExecutorPath to stdout file
__stderr_pathExecutorPath to stderr file
__sysinfoExecutorSystem info from probe
__cachedRunnerTrue if result came from cache
metricsExecutor/ParserExtracted metric values
Cache Integration
Cache Flow
│                      Runner Loop                            │
│   │ get_cached_     │──── HIT ────► Use cached metrics      │
│   │ result()        │              Skip execution           │
│          MISS                                               │
│   │ Execute test    │                                       │
│   │ store_result()  │──── SUCCEEDED ────► Cache for later   │
Cache Key
Results are keyed by parameter values (excluding cache_exclude_vars) and repetition number:
cache_key = hash(
    frozenset({k: v for k, v in params.items() if k not in exclude_vars}.items()),
    repetition
Budget Tracking
The runner tracks core-hour usage:
# After each test
if not used_cache:
    cores = evaluate(cores_expr, test.vars)  # e.g., "nodes * ppn"
    duration_hours = test.metadata["__sysinfo"]["duration_seconds"] / 3600
    core_hours = cores * duration_hours
    self.accumulated_core_hours += core_hours
    if self.accumulated_core_hours >= self.max_core_hours:
        self.budget_exceeded = True
        break
Status File Writing
The runner writes status files for monitoring:
def _write_status_file(self, test, status=None):
    if not execution_index:  # From probes config
        return
    # Determine status
    if status is None:
        status = test.metadata.get("__executor_status", "UNKNOWN")
    # Get duration from sysinfo
    sysinfo = test.metadata.get("__sysinfo")
    duration = sysinfo.get("duration_seconds") if sysinfo else None
    status_data = {
        "status": status,
        "error": test.metadata.get("__error"),
        "end_time": test.metadata.get("__end"),
        "cached": test.metadata.get("__cached", False),
        "duration_seconds": duration,
    # Write to repetition folder
    status_file = test.execution_dir / "__iops_status.json"
    status_file.write_text(json.dumps(status_data))
Source Code References
FilePurpose
iops/execution/runner.pyIOPSRunner class, main execution loop
iops/execution/planner.pyBasePlanner, ExhaustivePlanner, RandomSamplingPlanner, BayesianPlanner, AdaptivePlanner
iops/execution/executors.pyBaseExecutor, LocalExecutor, SlurmExecutor
iops/execution/matrix.pybuild_execution_matrix(), ExecutionInstance
iops/execution/cache.pyExecutionCache class
iops/execution/parser.pyparse_metrics_from_execution()
iops/results/writer.pysave_test_execution()
Key Entry Points
Function/MethodLocationPurpose
IOPSRunner.run()runner.pyMain execution loop
IOPSRunner.run_dry()runner.pyDry-run mode (no execution)
BasePlanner.next_test()planner.pyGet next test to execute
BasePlanner._prepare_execution_artifacts()planner.pyCreate folders and scripts
BaseExecutor.submit()executors.pySubmit/execute job
BaseExecutor.wait_and_collect()executors.pyWait and collect results
build_execution_matrix()matrix.pyGenerate parameter combinations
