Probe System
This page documents the IOPS system probe mechanism for developers who want to extend the collected metrics or modify probe behavior.
Overview
The probe system collects system information (CPU, memory, filesystems, etc.) from the actual compute node where the benchmark runs. This matters for SLURM jobs, where the login node differs from compute nodes.
Key files:
  • __iops_exit_handler.sh - Centralized EXIT trap coordinator
  • __iops_node_launcher.sh - Resolves the job’s node list and starts one helper per node
  • __iops_atexit_sysinfo.sh - System info collection script
  • __iops_sysinfo.json - Collected data (generated at runtime)
Architecture
User Script                     Exit Handler                    Sysinfo Script
│ #!/bin/bash         │        │ # Sets EXIT trap    │        │ # Registers cleanup │
│ #SBATCH ...         │        │ trap '_iops_run_    │        │ _iops_register_exit │
│                     │        │   exit_actions' EXIT│        │   "_iops_collect_   │
│ # IOPS injection    │        │                     │        │    sysinfo"         │
│ source handler.sh   │───────►│ # Registry array    │        │                     │
│ source sysinfo.sh   │───────────────────────────────────────►│ # Collection func   │
│                     │        │ _iops_register_exit │        │ _iops_collect_      │
│ # User's benchmark  │        │   () { ... }        │        │   sysinfo() { ... } │
│ mpirun ./benchmark  │        └─────────────────────┘        └─────────────────────┘
         ▼ (on script exit)              ▼
│ __iops_sysinfo.json │◄───────│ _iops_run_exit_     │
│ {                   │        │   actions() calls   │
│   "hostname": ...,  │        │ all registered      │
│   "cpu_model": ..., │        │ functions           │
│   "duration": ...   │        └─────────────────────┘
The exit handler provides a centralized EXIT trap that other IOPS features (system probe, resource sampler) register cleanup actions with, avoiding trap conflicts.
How It Works
1. Script Injection
When preparing execution artifacts, the planner writes all IOPS helper scripts and injects source lines into the user script:
# iops/execution/planner.py
def _inject_iops_scripts(self, script_text: str, exec_dir: Path) -> str:
    # 1. Write exit handler (always needed)
    handler_file = exec_dir / EXIT_HANDLER_FILENAME
    with open(handler_file, "w") as f:
        f.write(EXIT_HANDLER_TEMPLATE)
    # 2. Write node launcher (if any sampler is enabled)
    if resource_sampling or gpu_sampling or io_sampling:
        launcher_file = exec_dir / NODE_LAUNCHER_FILENAME
        with open(launcher_file, "w") as f:
            f.write(NODE_LAUNCHER_TEMPLATE)
    # 3. Write sysinfo script (if enabled)
    if collect_system_info:
        probe_script = SYSTEM_PROBE_TEMPLATE.format(execution_dir=str(exec_dir))
        probe_file = exec_dir / ATEXIT_SYSINFO_FILENAME
        with open(probe_file, "w") as f:
            f.write(probe_script)
    # 4. Inject source lines after shebang/#SBATCH
    # ... insertion logic ...
2. Exit Handler Mechanism
The exit handler sets a single EXIT trap and provides a registration function:
# __iops_exit_handler.sh
_IOPS_EXIT_ACTIONS=()
_iops_register_exit() {
    _IOPS_EXIT_ACTIONS+=("$1")
_iops_run_exit_actions() {
    for _iops_action in "${_IOPS_EXIT_ACTIONS[@]}"; do
        $_iops_action 2>/dev/null || true
    done
trap '_iops_run_exit_actions' EXIT
The sysinfo script registers its collection function:
# __iops_atexit_sysinfo.sh
_iops_register_exit "_iops_collect_sysinfo"
The probe therefore runs after the benchmark completes (success or failure), on the actual compute node, without affecting the script’s exit code or conflicting with other features’ cleanup actions.
3. Multi-Node Fan-Out
The sysinfo and version probes run once, in the job script’s own shell, so they describe the head node. The samplers instead need one instance per node, which is what __iops_node_launcher.sh provides. It is written whenever any sampler (resource_sampling, gpu_sampling, io_sampling) is enabled and sourced after the exit handler, before any sampler.
It exposes three functions:
FunctionPurpose
_iops_node_list()Prints the job’s unique node list, one hostname per line
_iops_remote_shell()Prints the command used to reach another node, empty when none is usable
_iops_launch_on_nodes()Starts one helper per node
Node list resolution tries each source in order and falls back to the local host:
SchedulerNode listLaunch method
SLURMscontrol show hostnames $SLURM_JOB_NODELISTone srun --overlap --ntasks-per-node=1 covering the allocation
OAR$OAR_NODEFILE (deduplicated)oarsh per remote node
PBS$PBS_NODEFILEssh -o BatchMode=yes per remote node
None detectedhostnamebackground process on the local node
# __iops_runtime_sampler.sh, when sourced
if declare -F _iops_launch_on_nodes >/dev/null 2>&1; then
    _iops_launch_on_nodes "${BASH_SOURCE[0]}" _iops_sampler_loop "$_IOPS_ATTEMPT_ID"
else
    _iops_sampler_loop </dev/null >/dev/null 2>&1 &
fi
Samplers detect whether they were sourced or executed. On the local node the launcher calls the sampling loop directly; on remote nodes it executes the same script standalone, which runs the loop only.
Two details make the remote case work:
  • Shared attempt id. Sentinel and trace paths are derived from IOPS_ATTEMPT_ID, then SLURM_JOB_ID, OAR_JOB_ID, PBS_JOBID, and finally the shell PID. The launcher passes IOPS_ATTEMPT_ID in the remote command, because a remote helper computing its own PID would watch a sentinel path that does not exist and exit immediately.
  • Shared execution directory. Remote helpers write their traces into the execution directory, so it must be visible from every node. When it is node-local the benchmark still succeeds, the remote traces simply stay on their nodes.
When adding a new per-node probe, call _iops_launch_on_nodes rather than testing scheduler variables directly, and keep the sourced-versus-executed check so the script can run standalone on a remote node. The I/O sampler (__iops_runtime_io_sampler.sh) is the newest example; it also shows the counter-source pattern, where IOPS_IO_DISKSTATS, IOPS_IO_MOUNTSTATS, IOPS_IO_SYSBLOCK, and IOPS_IO_SYSCLASSBLOCK override the /proc and /sys paths so the parsing can be tested against fixtures rather than live kernel counters. It resolves probes.io_paths inside _iops_io_resolve_targets rather than in Python, for the same reason the launcher resolves nodes at runtime: mount tables are a property of the node, not of the submitting host.
4. Data Collection
When the script exits, _iops_collect_sysinfo() runs and writes JSON to __iops_sysinfo.json:
_iops_collect_sysinfo() {
    _iops_sysinfo="{execution_dir}/__iops_sysinfo.json"
      echo "{"
      echo "  \"hostname\": \"$(hostname)\","
      echo "  \"cpu_model\": \"...\","
      # ... more fields
      echo "  \"duration_seconds\": ${SECONDS}"
      echo "}"
    } > "$_iops_sysinfo"
  ) 2>/dev/null || true
5. Data Retrieval
After execution, the executor reads the sysinfo and stores it in test metadata:
# iops/execution/executors.py
def _collect_system_info(self, test: ExecutionInstance) -> Optional[Dict]:
    sysinfo_path = Path(test.execution_dir) / SYSINFO_FILENAME
    with open(sysinfo_path, 'r') as f:
        return json.load(f)
# Called after test completion
sysinfo = self._collect_system_info(test)
if sysinfo:
    test.metadata["__sysinfo"] = sysinfo
Collected Fields
FieldSourceDescription
hostnamehostname commandCompute node hostname
cpu_model/proc/cpuinfoCPU model name
cpu_coresnproc commandNumber of CPU cores
memory_kb/proc/meminfoTotal memory in KB
kerneluname -rLinux kernel version
os/etc/os-releaseOS name and version
ib_devices/sys/class/infiniband/InfiniBand devices (comma-separated)
filesystemsdf -TDetected parallel filesystems
duration_seconds$SECONDSScript execution time
Parallel Filesystem Detection
The probe detects these parallel/distributed filesystems:
TypeDetection Method
Lustredf -T type = lustre
GPFSdf -T type = gpfs
BeeGFSdf -T type = beegfs
CephFSdf -T type = cephfs
PanFSdf -T type = panfs
WekaFSdf -T type = wekafs
PVFS2df -T type = pvfs2
OrangeFSdf -T type = orangefs
GlusterFSdf -T type = glusterfs
FUSE mountsdf -T type = fuse with known mount patterns
Output format: type:mountpoint,type:mountpoint,...
Example: lustre:/scratch,gpfs:/home
Design Decisions
Why Separate Files?
The probe is written as separate files (__iops_exit_handler.sh, __iops_atexit_sysinfo.sh) rather than inlined into the user script. This keeps user scripts clean and inspectable, makes each script debuggable on its own, guarantees identical probe code across scripts, and lets features be enabled or disabled independently.
Why Centralized Exit Handler?
A single EXIT trap with registration, instead of multiple traps, avoids trap conflicts between features, runs actions in a predictable (registration) order, and isolates failures so one action cannot break the others.
Why EXIT Trap?
Using trap ... EXIT instead of appending code at the end means collection runs even if the benchmark crashes or receives SIGTERM/SIGINT, and works regardless of the user script’s structure.
Why Subshell with || true?
    # ... collection code ...
The subshell with || true and stderr redirected guarantees the probe never changes the benchmark’s exit code and that probe failures stay silent and isolated.
Why $SECONDS?
The bash $SECONDS variable tracks time since script start with no explicit timing code, covering setup, benchmark, and cleanup time.
Configuration
Disabling the Probe
benchmark:
  probes:
    system_snapshot: false
When disabled:
  • __iops_atexit_sysinfo.sh is not written
  • __iops_sysinfo.json is not generated
  • duration_seconds is not available in status files
Note: The exit handler (__iops_exit_handler.sh) is still written if other features (like resource tracing) are enabled.
Impact on Features
FeatureWith ProbeWithout Probe
System info in reportsYesNo
duration_seconds in statusYesNo (uses timestamps)
Watch mode timingAccurateIncludes queue time
Cache durationAvailableNot available
Version Probe
The version probe captures software and library versions once per execution. This is metadata, not a measured metric, and it is the cache-mixing detector: the HTML report warns when a component reports more than one distinct version across executions, catching studies that mix fresh results with older cached results from a different software environment.
How It Works
  1. When benchmark.probes.versions is configured, _inject_iops_scripts() calls _build_version_probe_script() and writes the result to __iops_atexit_versions.sh in the repetition folder.
  2. The generated benchmark script sources __iops_atexit_versions.sh after the shebang/#SBATCH header. The script defines _iops_capture_versions() and registers it with the centralized exit handler via _iops_register_exit (falling back to immediate execution when no handler is present, e.g. standalone runs).
  3. Capture therefore runs after the benchmark body via the EXIT trap, in the same shell. This is deliberate: version tools are frequently only on PATH after the benchmark’s own module load commands, and the trap sees that modified environment.
  4. _iops_capture_versions() runs each configured command, captures its stdout (up to 4000 bytes), JSON-escapes it, and writes __iops_versions.json.
  5. Capture is best-effort: a failing command yields an empty string and does not abort the run.
benchmark:
  probes:
    versions:
      app: "myapp --version"
      mpi: "mpirun --version | head -1"
      compiler: "gcc --version | head -1"
Version Probe Script Structure
#!/bin/bash
# IOPS Version Probe - captures software/library versions once per execution.
_iops_capture_versions() {
    _iops_versions_file="/path/to/exec/repetition_1/__iops_versions.json"
    _iops_json_escape() { ... }
      echo "{"
      _iops_vraw=$( { myapp --version ; } 2>/dev/null | head -c 4000 )
      _iops_vesc=$(printf "%s" "$_iops_vraw" | _iops_json_escape)
      printf '  %s: "%s"\n' '"app"' "$_iops_vesc"
      echo "}"
    } > "$_iops_versions_file" 2>/dev/null
Output File
__iops_versions.json is written to each repetition directory:
  "app": "myapp 2.3.1",
  "mpi": "OpenMPI 4.1.5",
  "compiler": "gcc (GCC) 11.3.0"
Constants and functions for the version probe are listed in Source Code References below.
FilePurpose
iops/execution/planner.pyExit handler, probe templates, and script injection
iops/execution/executors.pySysinfo collection after execution
iops/execution/runner.pyStores sysinfo in status file
iops/reporting/report_generator.pyGallery and Software Versions HTML sections
Key Constants
EXIT_HANDLER_FILENAME = "__iops_exit_handler.sh"
ATEXIT_SYSINFO_FILENAME = "__iops_atexit_sysinfo.sh"
NODE_LAUNCHER_FILENAME = "__iops_node_launcher.sh"
EXIT_HANDLER_TEMPLATE = '''...'''
SYSTEM_PROBE_TEMPLATE = '''...'''
NODE_LAUNCHER_TEMPLATE = '''...'''
ATEXIT_VERSION_FILENAME = "__iops_atexit_versions.sh"
VERSIONS_FILENAME = "__iops_versions.json"
SYSINFO_FILENAME = "__iops_sysinfo.json"
Key Functions
FunctionLocationPurpose
_inject_iops_scripts()planner.pyWrites all IOPS scripts and modifies user script
_build_version_probe_script()planner.pyBuilds the version capture shell script
_collect_system_info()executors.pyReads sysinfo after execution
_iops_node_list()node launcherResolves the job’s node list per scheduler
_iops_remote_shell()node launcherPicks the remote shell (oarsh or ssh)
_iops_launch_on_nodes()node launcherStarts one helper per node of the allocation
_iops_register_exit()exit handlerRegisters cleanup action
_iops_run_exit_actions()exit handlerExecutes all registered actions
_iops_collect_sysinfo()sysinfo scriptBash function that collects data
_iops_detect_pfs()sysinfo scriptDetects parallel filesystems
_iops_capture_versions()version probe scriptBash function that captures software versions
_generate_versions_section()report_generator.pyRenders the Software Versions HTML section with drift detection
_load_execution_versions()report_generator.pyReads all __iops_versions.json files for a run
