Adaptive Variables
Adaptive variables let IOPS probe for threshold values by starting at an initial value and progressing until a stop condition is met. Use them to find limits such as maximum problem sizes, memory capacities, or performance cliffs without manually defining the search space.
Table of Contents
  1. Overview
  2. Basic Configuration
  3. Step Methods
  4. Stop Conditions
  5. Direction
  6. Safety Limits
  7. Probe Results
  8. Multiple Repetitions
  9. Combining with Swept Variables
  10. Staircase Search with an Escalating Variable
  11. Complete Example
  12. Constraints
  13. Configuration Reference
Overview
Unlike swept variables (which test a fixed list of values) or derived variables (which are computed from other variables), an adaptive variable is driven by a feedback loop:
  1. Start at an initial value
  2. Run the benchmark
  3. Evaluate a stop_when condition against the result
  4. If the condition is not met, advance the value (multiply, add, or compute) and repeat
  5. If the condition is met, record the last successful value and stop
When the config also has swept variables, each swept combination gets its own independent probe. For example, with nodes=[1, 2, 4] and an adaptive problem_size, IOPS runs three independent probes, one per node count.
Basic Configuration
benchmark:
  search_method: "adaptive"    # Required for adaptive variables
vars:
  problem_size:
    type: int
    adaptive:
      initial: 1000            # Starting value
      factor: 2                # Next = previous * 2
      stop_when: "exit_code != 0"  # Stop when benchmark fails
Only one adaptive variable is allowed per config. All other variables must use sweep or expr.
Step Methods
Exactly one of factor, increment, or step_expr must be specified to define how the adaptive value progresses.
Multiplicative (factor)
Each step multiplies the previous value by the factor: with initial: 1000 and factor: 2, the sequence is 1000, 2000, 4000, 8000, … For ascending direction, factor must be > 1; for descending, factor must be < 1.
Additive (increment)
Each step adds the increment to the previous value: with initial: 100 and increment: 50, the sequence is 100, 150, 200, 250, … For ascending direction, increment must be positive; for descending, negative.
Custom expression (step_expr)
A Jinja2 expression that computes the next value from previous and iteration:
adaptive:
  initial: 100
  step_expr: "{{ previous * 2 + 100 }}"  # Sequence: 100, 300, 700, 1500, ...
step_expr does not require numeric variable types (it can work with str types), while factor and increment require int or float.
Stop Conditions
The stop_when field is a Python expression evaluated after each execution completes. When it evaluates to True, the probe stops.
Available context
VariableTypeDescription
exit_codeint or NoneProcess return code (__returncode)
statusstrExecutor status (SUCCEEDED, FAILED, etc.)
metricsdictParsed metrics as a dict (e.g., metrics.get('bwMiB', 0))
metric namesanyEach parsed metric is also available directly by name (e.g., totalTime, bwMiB)
execution_timefloat or NoneWall-clock elapsed time in seconds (from executor timestamps)
previousanyThe adaptive value that was just tested (same name as in step_expr)
iterationint0-based iteration counter
Parsed metrics are available both directly by name and through the metrics dict:
stop_when: "totalTime > 2"                    # direct access
stop_when: "metrics.get('totalTime', 0) > 2"  # dict access (safer if metric might be missing)
Metric names cannot conflict with the built-in context variables listed above; IOPS validates this at config load time. Note that execution_time (wall-clock time from executor timestamps, including queue wait and setup) differs from timing metrics your parser returns (like IOR’s totalTime, which measures only the benchmark operation).
Examples
# Stop on non-zero exit code (the most common pattern)
# Stop when a metric degrades below a threshold
stop_when: "gflops < 50"
# Combine conditions with and/or:
# stop if benchmark crashes OR takes longer than 2 minutes
stop_when: "exit_code != 0 or (execution_time is not None and execution_time > 120)"
# Stop when benchmark succeeds but performance degrades
stop_when: "exit_code == 0 and gflops < 50"
Direction
The direction field declares the expected progression order: "ascending" (default, values increase) or "descending" (values decrease, e.g., initial: 1024 with factor: 0.5 gives 1024, 512, 256, …). Direction is used for validation only (ensuring factor/increment produce values in the expected order); it does not alter the step computation itself.
Safety Limits
Use max_iterations to cap the number of values tested:
adaptive:
  initial: 1000
  factor: 2
  max_iterations: 10           # Test at most 10 values
When the limit is reached, the probe stops even if the stop condition was never triggered. When max_iterations is omitted, the probe runs without a limit and only stops on the stop_when condition.
Probe Results
After all probes finish, IOPS records:
  • last_value_before_stop: The last adaptive value where stop_when was False, meaning the probe continued past it
  • stop_value: The value that triggered stop_when
  • iterations: Total number of values tested
  • stop_reason: "condition_met", "max_iterations", "constraint_violation", or "step_error"
A step_error means the next value could not be computed, most often a step_expr that indexes a list with fewer values than the probe asked for. That probe stops and the rest of the run continues; the error naming the variable, iteration, and previous value is written to the log. When max_iterations is set and the expression does not reference previous, IOPS catches this at config load time instead, so iops check reports it before any test runs.
Results are stored in the run metadata file (__iops_run_metadata.json) under the adaptive_results key and are displayed in the run summary logs:
Adaptive probing results for 'problem_size':
  nodes=1: stop_value=8000, last_value_before_stop=4000, iterations=4, stop_reason=condition_met
  nodes=2: stop_value=16000, last_value_before_stop=8000, iterations=5, stop_reason=condition_met
  nodes=4: last_value_before_stop=16000, iterations=10, stop_reason=max_iterations
These names describe the probe’s progression rather than success or failure, because stop_when decides what stopping means. With the usual "exit_code != 0", the probe stops on the first failure, so stop_value is the first failing value and last_value_before_stop is the largest working one. With an inverted condition such as "exit_code == 0" (keep stepping while it fails, stop at the first success), stop_value is the value that succeeded.
Note: before 3.5.9 these were named found_value and failed_value, which assumed that stopping meant failure and so read backwards for an inverted stop_when. Both names are still written to the metadata file and still work as attributes on the probe result; see Deprecations.
When benchmark.repetitions > 1 (e.g., repetitions: 3), the planner runs all repetitions for each adaptive value before evaluating stop_when. If any repetition triggers the stop condition, the probe stops at that value. This provides robustness against flaky results.
When adaptive and swept variables coexist, IOPS creates one independent probe per unique combination of swept variable values. The adaptive variable is excluded from the normal Cartesian product matrix; the planner builds the matrix from the swept variables only and assigns one probe per combination. With nodes=[1, 2, 4] and an adaptive problem_size, this creates 3 probes; each independently doubles problem_size until the benchmark fails for that specific nodes value, yielding a per-node-count maximum problem size.
How probes advance
Each probe tracks its own state and advances independently. When a new adaptive value is generated for one probe, only that specific swept combination is tested. Probes are served in round-robin order: IOPS emits all repetitions for the current value of one probe, then moves to the next probe, and cycles back.
Example with nodes=[1, 2, 4], problem_size adaptive (initial=1000, factor=2):
Probe 0 (nodes=1): problem_size=1000 ok
Probe 1 (nodes=2): problem_size=1000 ok
Probe 2 (nodes=4): problem_size=1000 ok
Probe 0 (nodes=1): problem_size=2000 ok
Probe 1 (nodes=2): problem_size=2000 ok
Probe 2 (nodes=4): problem_size=2000 ok
Probe 0 (nodes=1): problem_size=4000 FAIL  -> probe 0 finished (stop_value=4000, last_value_before_stop=2000)
Probe 1 (nodes=2): problem_size=4000 ok
Probe 2 (nodes=4): problem_size=4000 ok
Probe 1 (nodes=2): problem_size=8000 FAIL  -> probe 1 finished (stop_value=8000, last_value_before_stop=4000)
Probe 2 (nodes=4): problem_size=8000 ok
Probe 2 (nodes=4): problem_size=16000 FAIL -> probe 2 finished (stop_value=16000, last_value_before_stop=8000)
When probe 0 finishes, probes 1 and 2 keep going on their own. Each probe can reach a different threshold and run a different number of tests (here 3, 4, and 5).
Multiple swept variables
With multiple swept variables, the number of probes equals the size of the Cartesian product of all swept variables. For example, nodes=[1, 2, 4] and ppn=[8, 16] with an adaptive matrix_size creates 3 x 2 = 6 independent probes: (nodes=1, ppn=8), (nodes=1, ppn=16), (nodes=2, ppn=8), and so on. Each finds its own threshold for matrix_size.
A plain adaptive probe finishes as soon as stop_when triggers. Often that is not the end of the story: the run failed because some resource ran out, and giving that resource more would let the search continue. An escalating variable expresses exactly that.
vars:
  problem_size:
    type: int
    adaptive:                        # the workload axis
      initial: 1000
      increment: 1000
      max_iterations: 20
  number_of_blocks:
    type: int
    escalate:                        # the resource axis
      values: [1, 4, 16]
When the probe would stop, the escalating variable advances to its next value and the same adaptive value is retested rather than the probe finishing. The probe ends only when the escalation values run out.
escalate is a variable kind like sweep, expr, and adaptive, and cannot be combined with them on the same variable. At most one escalating variable is allowed, and it requires an adaptive variable to extend. The escalation is driven by the adaptive variable’s own stop_when, so there is only one condition to reason about.
How the staircase walks
With the config above, against a benchmark where each problem size needs more blocks than the last:
RunResultAction
problem_size=1000, number_of_blocks=1worksadvance problem_size
problem_size=2000, number_of_blocks=1failsescalate, retest 2000
problem_size=2000, number_of_blocks=4worksadvance problem_size
problem_size=3000, number_of_blocks=4failsescalate, retest 3000
problem_size=3000, number_of_blocks=16worksadvance problem_size
problem_size=4000, number_of_blocks=16failsescalation exhausted, finish
Only one axis moves per step, which is what keeps the search well defined. The cost is P + B - 1 runs for P workload values and B escalation values. Sweeping the resource axis instead, so each workload value restarts the search from the smallest resource, costs up to P x B.
Each swept variable combination gets its own independent staircase, exactly as it gets its own probe without escalation.
Reading the frontier
A staircase produces a frontier rather than a single threshold, reported per escalation value:
Adaptive probing results for 'problem_size' (escalating 'number_of_blocks'):
  (no swept vars):
    number_of_blocks=1: reached problem_size=1000
    number_of_blocks=4: reached problem_size=2000
    number_of_blocks=16: reached problem_size=3000
    stop_reason=escalation_exhausted, stopped at problem_size=4000
This reads along either axis: the smallest number_of_blocks each problem_size needs, or the largest problem_size each number_of_blocks can handle. They are the same three rows.
The frontier is also written to __iops_run_metadata.json under adaptive_results, as a frontier list alongside the usual fields, with escalate_var naming the escalating variable. An escalation value that never succeeded reports null, so a level is never credited with a value it did not actually run.
stop_reason is escalation_exhausted when the search ran out of escalation values. The other reasons apply unchanged: max_iterations if the workload axis hit its cap first, and constraint_violation or step_error as usual.
When not to use it
The staircase never goes back to an earlier escalation value. It assumes that a value which fails at one adaptive value also fails at every later one. That holds for capacity limits, where more of the resource never hurts.
It does not hold if the escalating variable can fail at the top end too, for example if a high process count fails on communication overhead where a lower one succeeded. In that case the search walks past working configurations without noticing. Sweep the resource axis instead, so every combination is tested.
Complete Example
This example finds the largest matrix that a DGEMM (dense matrix multiplication) kernel can process before exceeding a time limit, for each node count:
benchmark:
  name: "DGEMM Scaling Limit Finder"
  workdir: "./workdir"
  executor: "slurm"
  repetitions: 1
vars:
  nodes:
    type: int
    sweep:
      mode: list
      values: [1, 2, 4, 8]
  ppn:
    type: int
    sweep:
      mode: list
      values: [16]
  ntasks:
    type: int
    expr: "{{ nodes * ppn }}"
  matrix_size:
    type: int
    adaptive:
      initial: 1000
      factor: 2
      stop_when: "execution_time is not None and execution_time > 120"
      max_iterations: 12
  memory_per_task_mb:
    type: int
    expr: "{{ (matrix_size * matrix_size * 8 * 3) // (ntasks * 1024 * 1024) }}"
command:
  template: "dgemm_benchmark --size {{ matrix_size }} --np {{ ntasks }}"
scripts:
  - name: "dgemm"
    script_template: |
      #!/bin/bash
      #SBATCH --job-name=iops_{{ execution_id }}
      #SBATCH --nodes={{ nodes }}
      #SBATCH --ntasks={{ ntasks }}
      #SBATCH --ntasks-per-node={{ ppn }}
      #SBATCH --time=00:15:00
      #SBATCH --exclusive
      module load mpi blas
      mpirun {{ command.template }}
    parser:
      file: "{{ execution_dir }}/dgemm_result.json"
      metrics:
        - name: gflops
      parser_script: |
        import json
        def parse(file_path):
            with open(file_path) as f:
                data = json.load(f)
            return {"gflops": data["gflops"]}
output:
  sink:
    type: csv
    path: "{{ workdir }}/results.csv"
With 4 node counts and 1 ppn value, IOPS creates 4 probes. Each doubles matrix_size (1000, 2000, 4000, 8000, …) until the computation takes longer than 2 minutes. More nodes handle larger matrices because the work is distributed across more processes.
Constraints
  • Only one adaptive variable per config
  • Adaptive variables cannot appear in exhaustive_vars or cache_exclude_vars
  • benchmark.search_method must be "adaptive" when an adaptive variable is defined (adaptive cannot be combined with "bayesian", "random", or "exhaustive" search methods)
  • Adaptive probing cannot be used with SLURM single-allocation mode (allocation.mode: "single"), which pre-generates all tests upfront and leaves no feedback loop
  • factor and increment require numeric types (int or float); step_expr works with any type
  • Conditional variables (when) cannot reference the adaptive variable, because when conditions are evaluated during matrix generation before the adaptive value is known. Use only swept variables in when expressions.
  • At most one escalating variable per config, and it requires an adaptive variable to extend. Escalating variables are subject to the same rules as adaptive ones: excluded from exhaustive_vars, cache_exclude_vars, and when expressions.
Why only one adaptive variable?
A deliberate design choice that keeps the search well-defined and the results interpretable:
  • Search strategy. One adaptive variable steps forward in one dimension until it hits a wall; with two moving independently, there is no obviously correct way to advance them.
  • Stop condition attribution. With two adaptive variables moving at once, you cannot tell which one caused stop_when to trigger.
  • Result structure. One adaptive variable yields a simple last_value_before_stop / stop_value pair per probe; two would require a 2D boundary, which is closer to what Bayesian optimization handles with a surrogate model.
If the two variables are coupled, meaning one should advance precisely when the other stalls, use an escalating variable. That case is well defined because only one axis moves per step, which is what the objections above are really about.
If they are genuinely independent, sweep one and probe the other:
vars:
  block_factor:
    type: int
    sweep: { mode: list, values: [32, 64, 128, 256] }   # sweep this one
  matrix_size:
    type: int
    adaptive:
      initial: 1000
      factor: 2
      stop_when: "exit_code != 0"    # probe this one per block_factor
This gives the threshold matrix_size for each block_factor value, testing every combination. Alternatively, run two separate adaptive configs (one per variable) for fully independent threshold searches.
Adaptive vs Bayesian optimization
Adaptive probing and Bayesian optimization are separate search methods and cannot be used together in the same config:
  • Adaptive probes a single dimension to find a threshold (e.g., “what is the largest matrix size before running out of memory?”)
  • Bayesian explores a multi-dimensional space to find an optimal combination (e.g., “which nodes/ppn/block_factor combo maximizes GFLOPS?”)
A common two-step workflow is to run adaptive first to discover limits, then use those limits as sweep ranges for a Bayesian run:
# Step 1: adaptive config discovers max matrix_size per node count
# Result: nodes=4 -> 8000, nodes=8 -> 16000, nodes=16 -> 32000
# Step 2: Bayesian run with sweep values informed by adaptive results
benchmark:
  search_method: "bayesian"
  bayesian_config: { objective_metric: "gflops", objective: "maximize", n_iterations: 30 }
vars:
  nodes: { type: int, sweep: { mode: list, values: [4, 8, 16] } }
  matrix_size: { type: int, sweep: { mode: list, values: [1000, 2000, 4000, 8000, 16000] } }
adaptive
FieldRequiredDefaultDescription
initialYesStarting value
factorOne of threeMultiplicative step (next = previous * factor)
incrementOne of threeAdditive step (next = previous + increment)
step_exprOne of threeJinja2 expression for custom progression
stop_whenYesPython expression evaluated after each execution
max_iterationsNoNo limitMaximum number of values to test
directionNo"ascending"Expected progression: "ascending" or "descending"
escalate
valuesYesOrdered values to escalate through when the adaptive probe would stop
An escalating variable is always paired with an adaptive one. The adaptive variable provides the workload that grows; the escalating variable provides the resource that steps up whenever that growth stalls.
benchmark:
  name: "Blocks needed per problem size"
  executor: "local"
  search_method: "adaptive"     # required: escalate extends an adaptive probe
  repetitions: 1
vars:
  # Grows while the benchmark keeps working
  problem_size:
    type: int
    adaptive:
      initial: 1000
      increment: 1000
      max_iterations: 20
  # Steps up only when problem_size stalls
  number_of_blocks:
    type: int
    escalate:
      values: [1, 4, 16]
command:
  template: "./solver --size {{ problem_size }} --blocks {{ number_of_blocks }}"
scripts:
  - name: "probe"
    submit: "bash"
    script_template: |
      #!/bin/bash
output:
  sink:
    type: csv
Six runs against a solver that needs more blocks for every larger problem: (1000, 1) works, (2000, 1) fails so blocks escalate to 4 and 2000 is retested, (2000, 4) works, and so on until (4000, 16) fails with no larger block count left.
The same shape covers any resource-and-workload pair: MPI ranks against matrix size, memory per task against particle count, timeout against iteration count. Swap increment for factor or step_expr if the workload should grow multiplicatively or follow a fixed list.
A runnable version with a stub benchmark is in examples/adaptive_staircase/ in the IOPS repository.
