Bayesian Optimization
Bayesian optimization lets IOPS explore a parameter space to find configurations that maximize or minimize a target metric, using far fewer evaluations than exhaustive search. Instead of testing every combination, it builds a surrogate model from observed results and focuses on the most promising regions.
Table of Contents
  1. Overview
  2. Basic Configuration
  3. How IOPS Implements Bayesian Optimization
  4. Choosing a Surrogate Model
  5. Acquisition Functions
  6. Convergence and Early Stopping
  7. Combining with Exhaustive Variables
  8. Fallback to Exhaustive
  9. Configuration Reference
Overview
Bayesian optimization (BO) is a sequential, model-based strategy for optimizing expensive black-box functions. In benchmarking, each “function evaluation” is a full benchmark run that may take minutes or hours; BO reduces the number of runs needed by learning from previous results. Use it when runs are expensive and you want the best configuration without testing every combination. Prefer exhaustive or random search when the space is small enough to cover fully, when you need complete coverage for statistical analysis, or when there is no clear optimization target.
Install note: Bayesian optimization requires the scikit-optimize library:
pip install "iops-benchmark[bayesian]"
Note: Bayesian optimization cannot be used with SLURM single-allocation mode, which pre-generates all tests upfront and leaves no feedback loop. IOPS rejects this combination at config validation.
Basic Configuration
A minimal Bayesian optimization config requires search_method: "bayesian", an objective_metric (matching a parser metric), and at least one variable with multiple sweep values:
benchmark:
  name: "Throughput Optimization"
  workdir: "./workdir"
  executor: "local"
  bayesian_config:
    objective_metric: "throughput"
    objective: "maximize"
    n_iterations: 20
vars:
  nodes:
    type: int
    sweep:
      mode: list
      values: [1, 2, 4, 8]
  block_size:
    type: int
    sweep:
      mode: list
      values: [64, 128, 256, 512, 1024]
  transfer_size:
    type: int
    sweep:
      mode: range
      start: 1
      end: 16
command:
  template: "benchmark --nodes {{ nodes }} --bs {{ block_size }}k --xfer {{ transfer_size }}m"
scripts:
  - name: "bench"
    submit: "bash"
    script_template: |
      #!/bin/bash
      {{ command.template }}
    parser:
      file: "{{ execution_dir }}/output.txt"
      metrics:
        - name: throughput
      parser_script: |
        import re
        def parse(file_path):
            with open(file_path) as f:
                content = f.read()
            bw = float(re.search(r"Bandwidth: ([\d.]+)", content).group(1))
            return {"throughput": bw}
output:
  sink:
    type: csv
    path: "{{ workdir }}/results.csv"
This config has 4 x 5 x 16 = 320 possible combinations. With n_iterations: 20, IOPS tests only ~6% of the space while searching for the configuration that maximizes throughput.
The optimization loop
Each Bayesian iteration follows a four-step cycle:
1. ASK      Optimizer suggests a point in continuous space
2. MAP      Nearest-neighbor lookup finds the closest valid configuration
            from the pre-built execution matrix
3. EXECUTE  Run the benchmark (all repetitions)
4. TELL     Report the observed metric back to the optimizer
            (using the actual evaluated point, not the original suggestion)
The first n_initial_points iterations (default: 5) use random sampling to build an initial dataset. After that, the surrogate model guides each suggestion.
IOPS builds the full execution matrix upfront (all valid parameter combinations after constraint filtering), then uses a lookup table to map optimizer suggestions to real configurations. Every evaluated point is therefore a valid, constraint-respecting combination.
Parameter space encoding
The optimizer works in a continuous numerical space, so each variable type is encoded differently:
Integer and float ranges (sweep.mode: range) map directly to Integer or Real dimensions in scikit-optimize. The optimizer can suggest any value in the range; nearest-neighbor mapping selects the closest valid discrete point.
# Maps to Integer(low=1, high=16)
transfer_size: { type: int, sweep: { mode: range, start: 1, end: 16 } }
Numeric lists (sweep.mode: list with type: int or type: float) use ordinal encoding: values are sorted and the optimizer works with indices (0, 1, 2, …). This preserves the natural ordering, so the model can learn that index 3 tends to beat index 1, which categorical encoding cannot express.
# Sorted to [64, 128, 256, 512, 1024]
# Maps to Integer(low=0, high=4) where index 0 = 64, index 4 = 1024
block_size: { type: int, sweep: { mode: list, values: [256, 64, 1024, 128, 512] } }
String lists (type: str) use categorical encoding, since there is no meaningful ordering between string values.
# Maps to Categorical(categories=["read", "write", "mixed"])
operation: { type: str, sweep: { mode: list, values: ["read", "write", "mixed"] } }
Single-value variables (one-element lists, or ranges where start equals end) are excluded from the search space and treated as fixed constants in every evaluation.
Nearest-neighbor mapping
The optimizer suggests points in continuous space, but IOPS can only run configurations from the pre-built execution matrix, so each suggestion is mapped to the nearest valid configuration by squared Euclidean distance in index space. If the optimizer suggests index 2.7 for block_size (values [64, 128, 256, 512, 1024]), the nearest valid index is 3, corresponding to 512. Equidistant ties go to the lexicographically largest index vector, a deterministic tie-break that tends to favor higher parameter values.
The feedback step (TELL) always reports the point that was actually evaluated, not the original suggestion, so the surrogate model never learns incorrect parameter/outcome associations.
Feedback and metric aggregation
After a configuration finishes running, IOPS extracts the target metric from the parser results and reports it to the optimizer.
Repetitions. When benchmark.repetitions > 1, IOPS runs all repetitions before reporting and uses the best value across repetitions (maximum for objective: "maximize", minimum for objective: "minimize"), not the mean. This favors peak performance, which is typically more representative when variability comes from system noise.
Objective sign flip. scikit-optimize always minimizes. When objective: "maximize", IOPS transparently negates the metric before passing it to the optimizer (and negates it back for display).
The base_estimator option selects the surrogate model that approximates the relationship between parameters and the target metric. The default is RF (Random Forest).
ModelBest forStrengthsWeaknesses
RF (Random Forest)Mixed spaces, most casesLow variance, handles categorical/ordinal well, consistentSlightly less precise than GP on smooth functions
GP (Gaussian Process)Purely continuous spacesExcellent uncertainty estimates, smooth interpolationStruggles with categorical variables, scales poorly with many observations
ET (Extra Trees)Similar to RFSlightly faster trainingHigher variance than RF
GBRT (Gradient Boosted Trees)Large datasetsGood accuracy with many observationsMore sensitive to hyperparameters
Recommendation: Start with RF (the default); it gives the most consistent results across space shapes. Switch to GP only if all variables are continuous (integer or float ranges, no lists or strings) and the search space is smooth.
The acquisition function decides where to sample next, balancing exploration (trying unknown regions) against exploitation (refining known good regions).
FunctionParameterBehavior
EI (Expected Improvement)xi (default: 0.01)Balanced. Selects points where the expected improvement over the current best is highest. Good default for most cases.
PI (Probability of Improvement)xi (default: 0.01)Exploitative. Selects points most likely to improve over the current best, even by a small amount. Converges faster but may miss better optima.
LCB (Lower Confidence Bound)kappa (default: 1.96)Exploratory. Selects points where the model’s lower confidence bound is lowest. Higher kappa values increase exploration.
xi controls the exploration/exploitation trade-off for EI and PI: increase to 0.1 or higher for broader exploration, decrease toward 0 for more exploitation. kappa plays the same role for LCB; the default (1.96) corresponds to a 95% confidence interval.
For most benchmarking workloads, EI with the default xi: 0.01 works well. If the optimizer converges too quickly to a local optimum, increase xi or switch to LCB.
When the surrogate model believes it has found the optimum, it may repeatedly suggest configurations that map to already-visited points. IOPS detects this and provides two strategies.
Default behavior
By default (early_stop_on_convergence: false), when the optimizer’s suggestions keep mapping to visited points (after max_retries re-asks, default 10), IOPS randomly samples from the remaining unvisited configurations. The full iteration budget is spent even if the model has converged, and the random fallback often discovers configurations the model missed.
Each re-ask refits the surrogate model, so a high max_retries is expensive late in a large budget, where most suggestions collide with already-visited points. If runs with large n_iterations slow down sharply near the end, lowering max_retries (e.g. to 2-3) cuts that per-iteration retry cost; the optimizer falls back to random sampling from unvisited points sooner.
Optimization ends when either:
  • All n_iterations are exhausted
  • Every configuration in the search space has been visited
Early stopping with xi boost
When early_stop_on_convergence: true, IOPS tries to escape local optima before stopping:
  1. Convergence detected: Suggestions keep mapping to visited points.
  2. Xi boost: xi is multiplied by xi_boost_factor (default: 5.0) to push the acquisition function toward unexplored regions. The boost is exponential: on the k-th convergence event, xi becomes original_xi * xi_boost_factor^k.
  3. Random sample: A random unvisited configuration is evaluated to provide fresh data.
  4. Xi reset: If the optimizer then suggests a new (unvisited) point on its own, xi is restored to its original value and the convergence counter resets.
  5. Early stop: After convergence_patience (default: 3) consecutive convergence events, the optimization terminates.
bayesian_config:
  n_iterations: 50
  convergence_patience: 3       # Stop after 3 convergence events
  xi_boost_factor: 5.0          # xi multiplied by 5.0 each time
With the defaults, repeated convergence gives xi = 0.01, 0.05, 0.25, then early stop (the third event exceeds patience). Use early stopping to save compute time when continued exploration is unlikely to help; otherwise the default usually produces better final results because the random fallback occasionally discovers configurations the model undervalues.
Variables listed in benchmark.exhaustive_vars (e.g., exhaustive_vars: ["stripe_count"]) are removed from the optimizer’s search space and instead tested exhaustively at each selected point. This suits variables that should always be fully characterized (like a filesystem tuning parameter) while others are optimized.
The optimizer selects a point (e.g., nodes=4, block_size=256), IOPS tests it with every stripe_count value, and the best metric across those instances is reported back to the optimizer. With n_iterations: 10 and 3 stripe counts, that is 30 benchmark executions.
See Search Methods: Exhaustive Variables for a full example.
When n_iterations is greater than or equal to the total number of valid configurations, a surrogate model adds no value. By default (fallback_to_exhaustive: true), IOPS switches to exhaustive search in this case:
INFO: Requested n_iterations=50 >= total_space=32. Using full exhaustive search
      instead of Bayesian optimization.
When fallback_to_exhaustive: false, IOPS clamps n_iterations to the space size and runs the optimizer normally.
Thread usage on the orchestrator node
The Bayesian planner fits a surrogate model (Gaussian Process or tree ensemble) on every iteration. That fit calls into numpy/BLAS, which by default starts one compute thread per core. On a many-core machine, and especially on a shared login node, a single iops process then shows dozens of threads (visible as green rows in htop). The fits are tiny and gain nothing from those threads, so IOPS caps them to a single thread for the duration of the surrogate math.
This is purely a threading change: the suggested configurations are identical regardless of the cap. To raise or disable it, set IOPS_BLAS_THREADS before launching:
export IOPS_BLAS_THREADS=4   # allow up to 4 BLAS threads for the fit
export IOPS_BLAS_THREADS=0   # disable the cap (use the library default)
iops run config.yaml --use-cache
Note that this only affects the orchestrator process where iops runs. The benchmark itself (ior, mdtest, your MPI program) runs on the compute nodes via the executor and is unaffected.
All fields below go under benchmark.bayesian_config:
FieldDefaultDescription
objective_metric(required)Metric name to optimize. Must match a metric defined in scripts[].parser.metrics.
objective"minimize"Optimization direction: "minimize" or "maximize".
n_iterations20Total number of configurations to evaluate.
n_initial_points5Number of random samples before guided search begins. Must be less than n_iterations.
acquisition_func"EI"Acquisition function: "EI" (Expected Improvement), "PI" (Probability of Improvement), or "LCB" (Lower Confidence Bound).
base_estimator"RF"Surrogate model: "RF" (Random Forest), "GP" (Gaussian Process), "ET" (Extra Trees), or "GBRT" (Gradient Boosted Trees).
xi0.01Exploration/exploitation trade-off for EI and PI. Higher values encourage exploration.
kappa1.96Exploration parameter for LCB. Higher values encourage exploration.
fallback_to_exhaustivetrueSwitch to exhaustive search when n_iterations >= total search space size.
early_stop_on_convergencefalseStop when the optimizer converges instead of falling back to random sampling.
convergence_patience3Number of consecutive convergence events before early stopping (only used when early_stop_on_convergence is true).
xi_boost_factor5.0Multiplier applied to xi on each convergence event to encourage exploration (only used when early_stop_on_convergence is true).
max_retries10Number of times per iteration to re-ask the optimizer when its suggestion maps to an already-visited point before sampling randomly from unvisited points. Each retry refits the surrogate, so lower values speed up large budgets where suggestions frequently collide.
See also:
