Budget Control
IOPS can track core-hours consumption and automatically stop execution when a budget limit is reached, helping prevent exceeding compute allocations on HPC systems.
Table of Contents
- Configuration
- How Core-Hours Are Calculated
- Duration Source and Accuracy
- Budget Enforcement Behavior
- Dry-Run Estimation
- Cache Interaction
Configuration
Set a budget limit in your YAML config:
benchmark:
max_core_hours: 1000 # Stop after 1000 core-hours
cores_expr: "{{ nodes * processes_per_node }}"
Or from command line (overrides config value):
iops run config.yaml --max-core-hours 1000
| Option | Description |
max_core_hours | Maximum core-hours budget. Execution stops when reached. |
cores_expr | Jinja2 expression to compute cores per test. Defaults to 1 if not set. |
core_hours = cores × (duration_seconds / 3600)
cores: Evaluated fromcores_exprusing test variablesduration_seconds: Actual script execution time (see Duration Source)
Setting cores_expr Correctly
The cores_expr should reflect the cores you’re actually charged for on your HPC system:
# Total MPI tasks
# Fixed cores per node (e.g., exclusive mode with 128-core nodes)
cores_expr: "{{ nodes * 128 }}"
# From a derived variable
cores_expr: "{{ ntasks }}"
Important for exclusive mode: If you reserve entire nodes but only use some cores, set cores_expr to the total reserved cores ({{ nodes * 128 }} for 128-core nodes), not just the ones your application uses ({{ ntasks }} would undercount if you run only 64 tasks per node).
IOPS uses two sources for duration, in order of preference:
1. System Probe (Preferred)
When probes.system_snapshot: true (default), IOPS injects a probe into your scripts that captures the actual execution time using bash’s $SECONDS variable. This measures only the script runtime on the compute node.
2. Job Timestamps (Fallback)
If the system probe is disabled (probes.system_snapshot: false) or unavailable, IOPS falls back to job timestamps recorded during execution:
__submission_time: When the job was submitted (sbatch called)__job_start: When the job started running (transitioned from PENDING to RUNNING)__end: When the job completed
The fallback prioritizes __job_start over __submission_time, so queue wait time is excluded from core-hours calculations.
Accuracy implications:
| Executor | With Probe | Without Probe |
| Local | Accurate | Accurate (no queue) |
| SLURM | Accurate | Reasonably accurate (excludes queue wait) |
| Single-allocation | Accurate | Includes monitoring overhead |
Recommendation: Keep probes.system_snapshot: true (default) for accurate budget tracking with SLURM; it captures the exact script execution time.
IOPS checks the budget before submitting each test, not during execution. This means:
A test may exceed the budget: If a test is submitted when budget remains, it runs to completion even if its actual duration pushes the total past
max_core_hours.No mid-execution cancellation: Once a job is submitted to SLURM or starts locally, IOPS won’t kill it based on budget; it only prevents new submissions.
Example scenario:
Core-hours: 1178.74/1200.00 (98.2% used, 21.26 remaining)
SLURM job submitted: 3363545
Here, 21.26 core-hours remain. The next test is still submitted even if it requires 30 core-hours, so the final total may exceed 1200.
Why this design? Killing running HPC jobs wastes already-consumed resources, and partial results from interrupted jobs are often unusable. The budget serves as a guideline, not a hard cutoff.
Recommendation: Set max_core_hours slightly below your actual allocation, especially if individual tests consume significant core-hours.
Dry-Run Estimation
Estimate core-hours before running with --dry-run and --time-estimate:
# Single estimate (300 seconds per test)
iops run config.yaml --dry-run --time-estimate 300
# Multiple scenarios
iops run config.yaml --dry-run --time-estimate "300,600,900"
This shows estimated total core-hours, budget utilization, and how many tests fit within the budget.
Cache Interaction
When using cache (--use-cache), cached tests don’t count toward the budget (they’re not re-executed), and IOPS tracks and reports the core-hours saved by cache hits in progress logs and the final summary:
Core-hours: 93.30/1200.00 (7.8% used, 1106.70 remaining, 45.20 saved by cache)
Budget: 93.30 / 1200.00 core-hours (7.8% utilized) [OK]
Cache savings: 45.20 core-hours saved by cache hits
