Execution Backends
IOPS supports two execution backends for running benchmarks: local execution and SLURM cluster submission.
Table of Contents
Local Executor
Runs benchmarks directly on your local machine using subprocesses. Suited for development, small experiments, single-node benchmarks, and quick iterations.
benchmark:
workdir: "./workdir"
executor: "local"
scripts:
- name: "benchmark"
script_template: |
#!/bin/bash
set -euo pipefail
{{ command.template }}
Parallel Execution
By default, IOPS runs tests sequentially (one at a time). Run multiple tests concurrently by setting the parallel option:
benchmark:
parallel: 4 # Run up to 4 tests at the same time
Or from the command line: iops run config.yaml --parallel 4
The CLI flag overrides the YAML value.
Parallel execution works with both local and slurm executors. With the local executor, multiple subprocesses run simultaneously. With SLURM, multiple jobs are submitted and polled concurrently, reducing total wall-clock time when queue wait is short.
Planner Compatibility
Not all search methods support full parallelism. IOPS automatically caps the effective degree based on the planner:
| Search Method | Max Parallelism | Reason |
exhaustive | Unlimited | All tests are independent |
random | Unlimited | All tests are independent |
bayesian | 1 (sequential) | Optimizer needs results from each test to suggest the next |
adaptive | Number of probes | Each probe (one per swept-variable combination) is independent, but tests within a probe are sequential |
When the requested degree exceeds what the planner supports, IOPS logs a warning and uses the planner’s maximum.
Limitations
- Single-allocation mode (
slurm_options.allocation.mode: "single") runs all tests in one SLURM job script and is incompatible with parallel execution. Theparallelsetting is ignored with a warning. - Budget tracking remains accurate under parallel execution. Core-hours are accumulated atomically as tests complete.
- Result ordering in the output file may differ from sequential runs since tests complete in non-deterministic order.
SLURM Executor
Submits jobs to a SLURM cluster with automatic resource management and monitoring. Suited for large-scale, multi-node, and resource-intensive experiments.
benchmark:
name: "SLURM Benchmark"
workdir: "/scratch/$USER/benchmark"
executor: "slurm"
max_core_hours: 500
cores_expr: "{{ nodes * ppn }}"
vars:
nodes:
type: int
sweep: { mode: list, values: [2, 4, 8] }
ppn: # processes per node
type: int
expr: "16"
scripts:
- name: "mpi_benchmark"
script_template: |
#!/bin/bash
#SBATCH --job-name=bench_{{ execution_id }}
#SBATCH --nodes={{ nodes }}
#SBATCH --ntasks-per-node={{ ppn }}
#SBATCH --time=01:00:00
#SBATCH --output={{ execution_dir }}/stdout
#SBATCH --error={{ execution_dir }}/stderr
module load openmpi
Budget Control
Track core-hours consumption and stop execution when a budget limit is reached:
benchmark:
max_core_hours: 1000 # Stop after 1000 core-hours
cores_expr: "{{ nodes * processes_per_node }}"
Or from command line: iops run config.yaml --max-core-hours 1000
For detailed configuration, accuracy considerations, and cache interaction, see the Budget Control guide.
Job Monitoring
IOPS automatically submits jobs via sbatch, monitors status with squeue, handles job failures gracefully, and tracks resource usage.
Custom SLURM Commands
For systems with command wrappers or custom SLURM installations, you can customize the command templates used for job management. Commands are templates that support a {job_id} placeholder, replaced with the actual job ID at runtime:
benchmark:
executor: "slurm"
slurm_options:
commands:
submit: "sbatch" # Submit command
status: "squeue -j {job_id} --noheader --format=%T" # Job status query template
info: "scontrol show job {job_id}" # Job information template
cancel: "scancel {job_id}" # Job cancellation template
poll_interval: 30 # Status polling interval (seconds)
Example with wrapper and custom flags:
benchmark:
executor: "slurm"
slurm_options:
commands:
submit: "lrms-wrapper sbatch"
status: "lrms-wrapper -r {job_id} --custom-format" # Custom flags: -r instead of -j
info: "lrms-wrapper info {job_id}"
cancel: "lrms-wrapper kill {job_id}"
poll_interval: 10 # Check status every 10 seconds
Notes:
- The
{job_id}placeholder is required for status, info, and cancel commands. - The
poll_intervalcontrols how often (in seconds) IOPS checks job status during execution. Default is 30 seconds.
Single-Allocation Mode
By default, IOPS submits a separate SLURM job for each test (per-test mode). When this creates too much scheduler overhead (job limits, long queue waits, many small tests), set slurm_options.allocation.mode: "single" to run all tests within one SLURM allocation.
See the Single-Allocation Mode guide for configuration, search method restrictions, MPI setup, and complete examples.
