Execution Matrix Generation
How IOPS builds the parameter space from your variable definitions
Overview
IOPS generates an execution matrix from your variable definitions; each row is a unique parameter combination to test.
vars: Execution Matrix:
nodes: [1, 2] → | nodes | threads |
threads: [4, 8] | 1 | 4 |
| 1 | 8 |
| 2 | 4 |
| 2 | 8 |
Variable Types
Swept Variables
Variables with sweep define the parameter space. IOPS creates a Cartesian product of all swept variables.
vars:
nodes:
type: int
sweep:
mode: list
values: [1, 2, 4] # 3 values
block_size:
type: int
sweep:
mode: list
values: [64, 128] # 2 values
Result: 3 × 2 = 6 test combinations
Derived Variables
Variables with expr are computed from other variables. They don’t add to the matrix size.
vars:
nodes:
type: int
sweep:
mode: list
values: [1, 2, 4]
total_cores:
type: int
expr: "nodes * 8" # Computed per execution
Result: 3 combinations (derived variable doesn’t multiply)
Conditional Variables
Use when and default to make a swept variable conditional on another variable. This eliminates redundant combinations.
The Problem
Sweeping use_compression: [true, false] and compression_level: [1, 5, 9] unconditionally creates 2 × 3 = 6 combinations, but the 3 combinations with use_compression: false are redundant: the level is ignored, so they run the same test three times.
The Solution
vars:
use_compression:
type: bool
sweep:
mode: list
values: [true, false]
compression_level:
type: int
sweep:
mode: list
values: [1, 5, 9]
when: "use_compression" # Only sweep when true
default: 0 # Use 0 when false
With when: 3 + 1 = 4 combinations
| use_compression | compression_level | Notes |
| true | 1 | swept |
| true | 5 | swept |
| true | 9 | swept |
| false | 0 | default value |
Step-by-Step Example
Consider a benchmark where --threads only matters when --parallel is enabled:
vars:
parallel:
type: bool
sweep:
mode: list
threads:
type: int
sweep:
mode: list
values: [2, 4]
when: "parallel"
default: 1
command:
template: "benchmark {% if parallel %}--parallel --threads={{ threads }}{% endif %}"
IOPS processes parallel first (no dependencies), then threads: for parallel: true the when condition holds and [2, 4] is swept; for parallel: false the default 1 is used.
Final Matrix
| parallel | threads | command |
| true | 2 | benchmark --parallel --threads=2 |
| true | 4 | benchmark --parallel --threads=4 |
| false | 1 | benchmark |
Without when: 2 × 2 = 4 executions (2 redundant)
With when: 3 executions
Matrix Size Calculation
| Scenario | Formula | Example |
| All unconditional | Product of all sweep sizes | 3 × 2 × 4 = 24 |
| With conditional (simple) | Base + conditional expansions | 3 + 1 = 4 |
| Mixed | Depends on conditions | Varies |
Use --dry-run to see the actual matrix size before execution:
iops run config.yaml --dry-run
Tips
- Start simple: begin with unconditional variables, add
whento reduce redundant tests - Avoid circular dependencies: variable A’s
whencannot reference variable B if B’swhenreferences A - Use meaningful defaults: the
defaultvalue appears in results, so choose values that make sense for analysis
