Metadata Files
IOPS generates metadata files with the __iops_ prefix to track executions, enable fast lookups, and support report generation. This page documents each file, when it is written, and how to control its generation.
Table of Contents
- I/O Overhead Considerations
- Metadata Files Overview
- Controlling Metadata Generation
- File Reference
- Best Practices
Metadata files are written to the workdir during benchmark execution. They are small (typically a few KB each), but consider disabling them when:
- Workdir is on the tested filesystem: metadata writes can interfere with measurements; either disable them or place the workdir on a separate filesystem.
- Running thousands of sub-second tests: per-execution JSON writes may become noticeable.
- Using high-latency network filesystems: metadata writes can add latency between tests.
Metadata is safe when the workdir is on a separate filesystem from the test target, tests run for several seconds or longer, or you need iops find or iops report functionality.
Run-Level Files
Located in workdir/run_XXX/:
| File | Purpose |
__iops_run_metadata.json | Report generation (config, timing, variables) |
__iops_index.json | Fast execution lookup for iops find |
__iops_status_rollup.json | Aggregated per-repetition status for iops find and watch mode |
__iops_resource_summary.csv | Aggregated CPU/memory, GPU, and I/O metrics |
__iops_hooks.log | Output and exit status of fired hooks (only if hooks are configured and fired) |
__iops_kickoff.sh | Single-allocation mode execution script (SLURM only) |
__iops_plots/ | PDF exports of report plots (requires kaleido) |
Execution Tracking Files
Located in workdir/run_XXX/exec_XXXX/:
| File | Purpose |
__iops_params.json | Parameter values for this execution |
__iops_skipped | Marker file for skipped tests (only present if skipped) |
Located in workdir/run_XXX/exec_XXXX/repetition_X/:
| File | Purpose |
__iops_status.json | Repetition execution status |
Script Output Files
| File | Purpose |
stdout | Script standard output |
stderr | Script standard error |
post_stdout | Post-script standard output (if post-script defined) |
post_stderr | Post-script standard error (if post-script defined) |
parser_stdout | Parser script print() output (if any) |
parser_stderr | Parser script errors/warnings (if any) |
These files capture all output from script execution and parsing, useful for debugging failed tests; parser output files are only created if the parser produces output.
System Info Files
| File | Purpose |
__iops_exit_handler.sh | Centralized EXIT trap coordinator |
__iops_atexit_sysinfo.sh | System info collection script |
__iops_sysinfo.json | Hardware/environment info (generated at exit) |
__iops_atexit_versions.sh | Software version capture script (versions probe) |
__iops_versions.json | Captured software/library versions (generated at exit) |
Resource Tracing Files
| File | Purpose |
__iops_node_launcher.sh | Resolves the job’s node list and starts one sampler per node |
__iops_runtime_sampler.sh | CPU/memory sampling script |
__iops_trace_running | Sentinel file (signals CPU/memory samplers to run) |
__iops_trace_<host>.csv | Per-node CPU/memory trace data |
__iops_runtime_gpu_sampler.sh | GPU metrics sampling script |
__iops_gpu_trace_running | Sentinel file (signals GPU samplers to run) |
__iops_gpu_trace_<host>.csv | Per-node GPU trace data |
__iops_runtime_io_sampler.sh | I/O sampling script |
__iops_io_trace_running | Sentinel file (signals I/O samplers to run) |
__iops_io_trace_<host>.csv | Per-node I/O trace data |
__iops_io_targets_<host>.json | What each io_paths entry resolved to on that node |
Disable Execution Tracking
Disables __iops_index.json, __iops_params.json, __iops_skipped, and __iops_status.json:
benchmark:
probes:
execution_index: false
Impact: iops find and watch mode (--watch) will not work for these runs; reduces I/O by 3 small JSON writes per execution.
Disable System Information Collection
Disables __iops_atexit_sysinfo.sh and __iops_sysinfo.json:
benchmark:
probes:
system_snapshot: false
Impact: system environment info will not appear in HTML reports; removes the system info script injection from generated scripts; reduces I/O by 1 small JSON write per repetition.
Disable All Metadata
For minimal I/O overhead (only results output):
benchmark:
probes:
Note: __iops_run_metadata.json is always written as it’s required for iops report.
File Reference
Written: Once at the end of benchmark execution (or dry-run)
Purpose: Metadata about the benchmark run, used by iops report to generate HTML reports without re-running the benchmark.
Structure:
"iops_version": "3.0.0",
"benchmark": {
"name": "IOR Performance Study",
"description": "Benchmark description",
"executor": "slurm",
"repetitions": 3,
"timestamp": "2026-01-10T14:30:00.000000",
"test_count": 12,
"search_method": "exhaustive",
"hostname": "login-node",
"benchmark_start_time": "2026-01-10T14:00:00.000000",
"benchmark_end_time": "2026-01-10T14:30:00.000000",
"total_runtime_seconds": 1800.0,
"planner_stats": {
"total_combinations": 48,
"active_combinations": 36,
"skipped_by_constraints": 12
"system_environment": {
"hostname": "compute-001",
"cpu_model": "Intel Xeon Gold 6248",
"cpu_cores": 40,
"memory_kb": 196608000
"variables": {
"nodes": {"type": "int", "swept": true, "sweep": {"mode": "list", "values": [1, 2, 4]}},
"ppn": {"type": "int", "swept": false}
"metrics": [
{"name": "throughput", "script": "benchmark"}
"output": {
"type": "csv",
"path": "results.csv"
"command": {
"template": "mpirun -np {{ nodes * ppn }} ./benchmark"
"reporting": {}
Cannot be disabled - required for report generation.
__iops_index.json
Written: Incrementally updated as each execution is prepared
Purpose: Indexes all executions with their parameters and paths, enabling fast lookup by iops find.
Structure:
"benchmark": "IOR Performance Study",
"executions": {
"exec_0001": {
"path": "exec_0001",
"params": {
"nodes": 1,
"ppn": 4,
"block_size": 1024
"command": "mpirun -np 4 ./benchmark --nodes 1"
All paths are relative to the run root, making workdirs portable across systems.
Controlled by: benchmark.probes.execution_index
__iops_params.json
Written: When the execution folder is created, before the test runs
Purpose: Stores parameter values for a specific execution, enabling iops find to filter by parameter values.
Structure:
"nodes": 4,
"ppn": 8,
"block_size": 4096
__iops_skipped
Written: When a test is skipped (constraint violation or planner decision)
Purpose: Marker file for skipped tests; if absent, watch mode assumes the test is pending or active.
Structure:
"reason": "constraint:nodes * ppn <= 64",
"message": "Optional detailed message"
Fields:
| Field | Description |
reason | Why the test was skipped (constraint rule, planner decision, etc.) |
message | Optional detailed explanation |
__iops_status.json
Location: workdir/run_001/exec_0001/repetition_1/__iops_status.json
Written: When a job is submitted (initial status), after each repetition completes or fails, and during SLURM job execution when status changes (PENDING → RUNNING)
Purpose: Tracks repetition execution status for iops find filtering and watch mode, including real-time status updates during SLURM jobs.
Structure:
"status": "SUCCEEDED",
"error": null,
"end_time": "2026-01-09T14:23:45.678901",
"cached": false,
"duration_seconds": 125.3
Status values:
| Status | Meaning |
SUCCEEDED | Execution completed successfully |
FAILED | Execution failed with non-zero exit code |
ERROR | Error during setup or execution |
RUNNING | Currently executing |
PENDING | Waiting in queue (SLURM jobs) |
UNKNOWN | Status could not be determined |
Initial status by executor:
| Executor | Initial Status | Reason |
local | RUNNING | Local jobs start executing immediately |
slurm | PENDING | SLURM jobs go to queue before running |
Other fields:
error- error message when status is FAILED or ERRORcached-trueif the result was retrieved from cache (set when running with--use-cacheand a cached result is found)duration_seconds- actual execution time in seconds from the probe script, available for both executed and cached results (the sysinfo is stored in the cache)
Written: Maintained by the runner during execution (flushed periodically) and finalized when the run ends.
Purpose: A single run-root aggregate of every repetition’s status, mirroring the per-folder __iops_status.json files keyed by execution and repetition. It lets iops find and watch mode read one file instead of scanning every execution folder, which keeps them fast on large parameter spaces (thousands of executions). The per-folder status files remain the source of truth; the roll-up is an accelerator with a folder-scan fallback.
Structure:
"benchmark": "My Study",
"repetitions": 3,
"complete": false,
"executions": {
"exec_0001": {
"reps": {
"1": { "status": "SUCCEEDED", "cached": false, "duration_seconds": 12.3, "metrics": {"bandwidth": 980.0} },
"2": { "status": "RUNNING" }
Fields:
complete-falsewhile the run is in progress,trueonce the runner finishes. Watch mode always reads the roll-up (a small lag is fine for a live monitor);iops findonly trusts it whencompleteistrueand otherwise falls back to scanning folders, so an interrupted or abruptly killed run stays correct.executions.<exec>.reps.<n>- the exact status dict that was written to that repetition’s__iops_status.json.
Controlled by: benchmark.probes.execution_index (same switch as the per-folder status files).
Location: workdir/run_001/exec_0001/repetition_1/__iops_exit_handler.sh
Written: When the repetition folder is created, before the test runs
Purpose: Centralized EXIT trap that coordinates cleanup for all IOPS features. The generated benchmark script sources this file first; it sets a single EXIT trap, and other IOPS scripts register cleanup functions via _iops_register_exit instead of setting their own traps, avoiding trap conflicts. On exit, registered functions run in order.
Always written when any IOPS feature is enabled.
Location: workdir/run_001/exec_0001/repetition_1/__iops_atexit_sysinfo.sh
Purpose: Collects system information from compute nodes. The generated benchmark script sources it after the exit handler; it registers _iops_collect_sysinfo, which writes __iops_sysinfo.json when the script exits (success or failure). This ensures system info is collected even if the benchmark fails, and on the actual compute node (important for SLURM jobs).
Controlled by: benchmark.probes.system_snapshot
__iops_sysinfo.json
Location: workdir/run_001/exec_0001/repetition_1/__iops_sysinfo.json
Written: At the end of script execution (via exit handler)
Purpose: Contains hardware and environment information from the compute node where the test ran.
Structure:
"hostname": "compute-042",
"cpu_model": "Intel(R) Xeon(R) Gold 6248 CPU @ 2.50GHz",
"cpu_cores": 40,
"memory_kb": 196608000,
"kernel": "5.15.0-91-generic",
"os": "Ubuntu 22.04.3 LTS",
"ib_devices": "mlx5_0,mlx5_1",
"filesystems": "lustre:/scratch,gpfs:/home",
Fields:
hostname | Compute node hostname |
cpu_model | CPU model from /proc/cpuinfo |
cpu_cores | Number of CPU cores (from nproc) |
memory_kb | Total memory in KB |
kernel | Linux kernel version |
os | Operating system name and version |
ib_devices | InfiniBand devices (comma-separated) |
filesystems | Detected parallel filesystems (type:mountpoint) |
duration_seconds | Script execution time in seconds |
Detected parallel filesystems: Lustre, GPFS, BeeGFS, CephFS, PanFS, WekaFS, PVFS2, OrangeFS, GlusterFS
Location: workdir/run_001/exec_0001/repetition_1/__iops_atexit_versions.sh
Written: When the repetition folder is created, before the test runs (when benchmark.probes.versions is configured)
Purpose: Captures software and library versions for the execution. The generated benchmark script sources it, registering the capture function with the centralized exit handler. On exit, after the benchmark body (so tools loaded by the benchmark’s own module load commands are in scope), it runs each configured command, captures stdout (up to 4000 bytes), and writes __iops_versions.json. Capture is best-effort: a failing command records an empty string rather than aborting the run.
Controlled by: benchmark.probes.versions
Location: workdir/run_001/exec_0001/repetition_1/__iops_versions.json
Written: On script exit, after the benchmark body has run (via the exit handler)
Purpose: Contains software and library versions captured by the version probe. The HTML report reads these files to render the Software Versions section. The same values are also written to the results sink as version.<component> columns, so versions can be queried alongside the metrics.
Structure:
"app": "myapp 2.3.1",
"mpi": "OpenMPI 4.1.5",
"compiler": "gcc (GCC) 11.3.0"
Each key is the component name defined in benchmark.probes.versions. The value is the trimmed stdout of the configured command, or an empty string if the command failed.
Drift detection: During report generation, components with more than one distinct value across executions trigger a drift warning in the Software Versions section (the study may mix results from different software environments or cached results from an older run).
Location: workdir/run_001/exec_0001/repetition_1/__iops_node_launcher.sh
Purpose: Resolves the job’s node list and starts one sampler per node. The generated benchmark script sources it after the exit handler and before any sampler. It detects SLURM (scontrol show hostnames, launched with srun --overlap), OAR ($OAR_NODEFILE, launched with oarsh) and PBS ($PBS_NODEFILE, launched with ssh), and falls back to the local node when no scheduler is detected. It also forwards the attempt id to remote nodes so every node of a job agrees on the sentinel and trace file names.
Controlled by: benchmark.probes.resource_sampling or benchmark.probes.gpu_sampling (written when either sampler is enabled)
Location: workdir/run_001/exec_0001/repetition_1/__iops_runtime_sampler.sh
Purpose: Collects CPU and memory utilization during benchmark execution. The generated benchmark script sources it after the exit handler. It creates the sentinel file __iops_trace_running and starts sampling: locally in the background for single-node jobs, or on every allocated node through __iops_node_launcher.sh for multi-node jobs (SLURM, OAR, PBS). Each node writes its own trace file (__iops_trace_<hostname>.csv). On exit, the exit handler removes the sentinel file, stopping all samplers.
Location: workdir/run_001/exec_0001/repetition_1/__iops_runtime_io_sampler.sh
Purpose: Collects read and write volume and operation counts during benchmark execution, from block devices (/proc/diskstats) and NFS mounts (/proc/self/mountstats). Each row is tagged with its source, and with the probes.io_paths entry it was resolved from, so a local disk and a network filesystem can be told apart. Only the filesystems behind the configured paths are sampled. Follows the same architecture as the CPU/memory sampler: a sentinel file (__iops_io_trace_running), local or multi-node sampling through the node launcher, one trace file per node, and shutdown via the exit handler. Skips silently when neither counter source is readable.
Controlled by: benchmark.probes.io_sampling
__iops_io_targets_<hostname>_<attempt_id>.json
Location: workdir/run_001/exec_0001/repetition_1/__iops_io_targets_<hostname>_<attempt_id>.json
Written: Once per node when I/O sampling starts, if probes.io_paths is set
Purpose: Records what each configured path resolved to on that node: the counter kind (block, nfs, or none), the device or export behind it, its mount point, and its filesystem type. Paths resolve per node because mount tables differ across an allocation. Check this file first when an I/O metric reads zero: a path on tmpfs has no counters to read, and shows up here as "kind": "none".
Controlled by: benchmark.probes.io_paths
Location: workdir/run_001/exec_0001/repetition_1/__iops_trace_running
Written: When resource tracing starts (before benchmark runs)
Removed: When benchmark script exits (via exit handler)
Purpose: Sentinel file that signals resource samplers to keep running. Removing it gracefully terminates all samplers, including those on remote nodes in multi-node jobs.
Location: workdir/run_001/exec_0001/repetition_1/__iops_trace_<hostname>.csv
Written: Continuously during benchmark execution by the resource sampler
Purpose: Contains per-core CPU and memory utilization samples, one file per node.
Format:
timestamp,hostname,core,cpu_user_pct,cpu_system_pct,cpu_idle_pct,mem_total_kb,mem_available_kb
1705123456.123,node01,0,45.2,5.1,49.7,128000000,64000000
1705123456.123,node01,1,42.1,4.8,53.1,128000000,64000000
Location: workdir/run_001/exec_0001/repetition_1/__iops_runtime_gpu_sampler.sh
Written: During artifact preparation (before benchmark runs)
Purpose: Collects GPU metrics (utilization, memory, temperature, power draw, clock speeds) at configurable intervals. Currently supports NVIDIA GPUs via nvidia-smi (detected with command -v nvidia-smi), with vendor detection designed for future AMD and Intel support; gracefully skips if no supported GPU is detected. Follows the same architecture as the CPU/memory sampler: a sentinel file (__iops_gpu_trace_running), local or multi-node sampling through the node launcher, one trace file per node, and shutdown via the exit handler.
Controlled by: benchmark.probes.gpu_sampling
Location: workdir/run_001/exec_0001/repetition_1/__iops_gpu_trace_running
Written: When GPU tracing starts (before benchmark runs)
Purpose: Sentinel file that signals GPU samplers to keep running; independent of the CPU/memory sampler sentinel.
Location: workdir/run_001/exec_0001/repetition_1/__iops_gpu_trace_<hostname>.csv
Written: Continuously during benchmark execution by the GPU sampler
Purpose: Contains GPU metrics samples for all GPUs on each node, one file per node.
Format:
timestamp,hostname,gpu_index,gpu_name,utilization_gpu_pct,utilization_mem_pct,memory_used_mib,memory_total_mib,temperature_c,power_draw_w,clock_sm_mhz,clock_mem_mhz
1705123456.5,node01,0,NVIDIA A100-SXM4-80GB,85,40,30000,81920,62,250.50,1410,1215
__iops_kickoff.sh
Written: When using single-allocation mode, before submitting to SLURM
Purpose: The execution script submitted via sbatch that runs all tests sequentially within a single SLURM allocation.
Structure:
#!/bin/bash
#SBATCH --nodes=8
#SBATCH --time=02:00:00
#SBATCH --partition=batch
#SBATCH --exclusive
# IOPS-managed directives
#SBATCH --job-name=iops_single_alloc
#SBATCH --output=/path/to/workdir/logs/single_alloc_%j.out
#SBATCH --error=/path/to/workdir/logs/single_alloc_%j.err
# User setup commands (modules, env vars from allocation_script)
module purge
module load mpi/openmpi/4.0.1
# IOPS-generated test dispatcher
run_test() {
# Runs each test with timeout, writes status to __iops_status.json
# Sequential test execution
run_test "/path/to/exec_0001/repetition_001" "run_script.sh" "exec_0001" "1"
Key features:
- User-provided SBATCH directives come from
allocation_script; IOPS adds the shebang, job-name (iops_single_alloc), and output/error paths - User setup commands (module loads, exports) run once at the start
- Tests run sequentially via the
run_test()dispatcher; each respectstest_timeout(default: 3600s) - Status files (
__iops_status.json) updated for each test (RUNNING → SUCCEEDED/FAILED/TIMEOUT)
Controlled by: slurm_options.allocation.mode: "single"
__iops_plots/
Written: When generating HTML reports via iops report --export-plots (requires kaleido)
Purpose: Contains image exports of all plots from the HTML report, for use in publications or presentations.
Structure:
__iops_plots/
├── 001_test_summary.pdf
├── 002_best_configurations_bandwidth.pdf
File naming: Files are numbered in report order (001, 002, …); names include the plot type and metric, with special characters sanitized to underscores; the extension matches the chosen format (pdf, png, svg, jpg, webp).
Controlled by: --export-plots flag when running iops report (use --plot-format FORMAT to select the format, default: pdf). Requires the kaleido package (pip install "iops-benchmark[plots]").
Best Practices
For I/O Benchmarks
When benchmarking storage systems, place your workdir on a different filesystem than the one being tested (e.g., workdir: "/local/scratch/iops_workdir" while the benchmark targets /lustre/project/data). If you must use the same filesystem, disable metadata:
benchmark:
name: "Lustre I/O Benchmark"
workdir: "/lustre/project/benchmark"
probes:
For Production Runs
Keep metadata enabled for post-run analysis with iops find, HTML report generation, debugging failed executions, and watch mode monitoring.
For Large Parameter Sweeps
With thousands of executions, consider:
- Using
create_folders_upfront: false(default) to create folders lazily - Placing workdir on a fast local filesystem (SSD if available)
