Resource Sampling
IOPS can optionally sample CPU, memory, GPU, and I/O activity during benchmark execution, so you can correlate parameter configurations with resource footprint (e.g., heatmap analysis of how parameters affect resource usage).
Warning: Performance Impact
Resource sampling runs background processes that periodically collect system metrics and write to CSV files. Although the samplers run at low priority (via renice), they may still affect benchmark results: a small amount of CPU time for reading proc files, an nvidia-smi invocation per GPU sample, one CSV append per sample interval, and ~1-2 MB of memory per process. For performance-critical measurements, run your benchmark without sampling first to establish a baseline, then enable sampling in a separate run to collect resource data.
Quick Start
Enable resource sampling in your configuration:
benchmark:
  name: "My Benchmark"
  probes:
    resource_sampling: true    # CPU/memory sampling (default: false)
    gpu_sampling: true         # GPU sampling (default: false)
    io_sampling: true          # I/O sampling (default: false)
    io_paths:                  # Required with io_sampling: what storage to measure
      - "{{ execution_dir }}"
    sampling_interval: 1.0     # Sample every 1 second (default)
How It Works
CPU/Memory Sampling
When probes.resource_sampling: true, IOPS injects a resource sampler (__iops_runtime_sampler.sh) into each benchmark script. The sampler runs with low priority (renice -n 19), reads /proc/stat and /proc/meminfo at the configured interval, and writes per-node, per-attempt sample files (__iops_trace_<hostname>_<attempt_id>.csv). A per-attempt sentinel file (__iops_trace_running.<attempt_id>) controls graceful termination: the sampler stops when the exit handler removes its sentinel.
GPU Sampling
When probes.gpu_sampling: true, IOPS injects a GPU sampler (__iops_runtime_gpu_sampler.sh) that detects the GPU vendor at runtime (currently NVIDIA via nvidia-smi, designed for future AMD/Intel support), queries all GPUs in a single call per interval, and writes per-node, per-attempt GPU sample files (__iops_gpu_trace_<hostname>_<attempt_id>.csv). It gracefully skips if no supported GPU is detected (no errors, no empty files) and uses its own per-attempt sentinel file (__iops_gpu_trace_running.<attempt_id>), independent of the CPU sampler.
I/O Sampling
When probes.io_sampling: true, IOPS injects an I/O sampler (__iops_runtime_io_sampler.sh) that reads two independent counter sources each interval and writes per-node, per-attempt sample files (__iops_io_trace_<hostname>_<attempt_id>.csv), with its own sentinel (__iops_io_trace_running.<attempt_id>).
Two sources are needed because neither one alone describes both a local disk and a network filesystem:
SourceRead fromCoversReports nothing for
block/proc/diskstatsLocal disks, NVMeNFS, whose traffic never reaches a client block device
nfs/proc/self/mountstatsNFS mounts, per mountLocal disks
Each row is tagged with its source, so a study comparing storage backends can tell them apart rather than seeing one arm report zero.
Scoping to the storage you care about
io_paths is required whenever io_sampling is enabled. It names the paths whose storage should be measured, and the probe counts only the filesystems holding them. There is no “measure everything” mode on purpose: a node usually has storage the benchmark never touches, so counting all of it would produce a number that does not describe the run.
benchmark:
  probes:
    io_sampling: true
    io_paths:
      - "{{ execution_dir }}"      # where this execution writes
      - "/scratch/shared/input"    # where it reads from
Paths are Jinja2 templates rendered per execution, so they can reference {{ execution_dir }} or any swept variable, exactly like command.template. Each path is resolved on the compute node, since mount tables differ across an allocation, and a path the benchmark has not created yet resolves through its nearest existing ancestor.
Resolution maps a path to a counter:
The path lives onResolved toPrecision
A local filesystemThe whole block device behind it (a partition resolves to its parent disk, an LVM or md volume to the disks underneath)Device-level
An NFS mountThat mount’s client countersMount-level, exact
tmpfs, ramfs, or anything with no backing deviceNothing countableReported, not counted
Device-level is not path-level. Scoping to /tmp restricts the counters to the disk holding /tmp. If / lives on that same disk, its traffic is still included. NFS scoping is exact because the kernel keeps counters per mount; block scoping is only as precise as the device layout. To measure a local filesystem cleanly, give it its own device.
How several paths are combined
io_paths is a filter, not a per-path breakdown. Every path is resolved to a counter, the counters are deduplicated, and the summary metrics are totals over that set. What you can separate depends on where the paths landed:
The paths land onIn the traceIn the summary
Different filesystemsOne row per device or mount each interval, each labelled with the path it came fromTotals, plus the io_disk_* and io_nfs_* split when one is local and the other is NFS
The same filesystemOne row, labelled with every path that resolved to it, joined by ;Totals only
Two directories on the same disk cannot be told apart, because the kernel keeps no per-directory counters. The device is registered once so its traffic is counted once rather than twice, and the path column names both, which is the honest answer rather than crediting whichever path happened to be resolved last.
So listing an input directory and an output directory that share a filesystem gives you their combined traffic, correctly, with no double counting. To attribute them separately they have to be on separate devices or separate NFS mounts. For finer analysis than the summary offers, read the trace CSV: it carries source, device, and path per sample.
A path that resolves to nothing countable, such as anything on tmpfs, is not silently ignored: the run logs a warning naming the path and its filesystem type, and every node records what each path resolved to in __iops_io_targets_<hostname>_<attempt_id>.json next to the trace.
Two more things to know before drawing conclusions from the numbers:
  • The counters are node-level, not process-level. They include anything else running on the node that touches the same storage. On a dedicated compute node in a batch job that is what you want; on a shared machine it is noise.
  • NFS byte counts are what crossed the wire. The probe reads the server-read and server-written counters, not the normal-read counters, so reads the page cache satisfied locally are excluded. Comparing an NFS arm against a local-disk arm is therefore comparing like with like: both count traffic that reached storage.
Block devices are counted once. Partitions (sda1) are excluded because their traffic is already in the parent device, and virtual devices (dm-*, md*, loop*) are excluded because they would double count the disks underneath them.
Other filesystems (Lustre, GPFS) are not yet read. They plug in as additional counter sources in the same way the GPU sampler is designed to gain AMD and Intel support.
All three samplers share the sampling_interval setting and support multi-node jobs on SLURM, OAR and PBS.
Output Files
Per-Execution CPU/Memory Sample Files
Each execution produces one CSV file per node:
Location: workdir/run_001/exec_0001/repetition_001/__iops_trace_<hostname>_<attempt_id>.csv
attempt_id is the scheduler job id (SLURM_JOB_ID, OAR_JOB_ID or PBS_JOBID), falling back to the shell PID when running outside a scheduler. Every node of a job uses the same value. Including it in the filename prevents a second attempt (e.g. when SLURM requeues the job after a node failure) from truncating the first attempt’s trace, and prevents one attempt’s exit handler from stopping another attempt’s sampler. Post-mortem aggregation picks up every matching file, so if an attempt aborts and leaves a short partial trace on disk, you may want to delete that file before running the report.
Format:
timestamp,hostname,core,cpu_user_pct,cpu_system_pct,cpu_idle_pct,mem_total_kb,mem_available_kb
1705123456.123,node01,0,45.2,5.1,49.7,128000000,64000000
1705123456.123,node01,1,42.1,4.8,53.1,128000000,64000000
Fields:
FieldDescription
timestampUnix timestamp with milliseconds
hostnameNode hostname
coreCPU core number (0-indexed)
cpu_user_pctUser CPU utilization (%)
cpu_system_pctSystem CPU utilization (%)
cpu_idle_pctIdle CPU (%)
mem_total_kbTotal memory in KB
mem_available_kbAvailable memory in KB
Per-Execution GPU Sample Files
When gpu_sampling is enabled and a supported GPU is detected, each execution produces one GPU sample CSV per node:
Location: workdir/run_001/exec_0001/repetition_001/__iops_gpu_trace_<hostname>_<attempt_id>.csv
Format:
timestamp,hostname,gpu_index,gpu_name,utilization_gpu_pct,utilization_mem_pct,memory_used_mib,memory_total_mib,temperature_c,power_draw_w,clock_sm_mhz,clock_mem_mhz
1705123456.5,node01,0,NVIDIA A100-SXM4-80GB,85,40,30000,81920,62,250.50,1410,1215
1705123457.5,node01,0,NVIDIA A100-SXM4-80GB,92,45,32000,81920,64,275.30,1410,1215
Fields:
FieldDescription
gpu_indexGPU device index (0-indexed)
gpu_nameGPU model name
utilization_gpu_pctGPU compute utilization (%)
utilization_mem_pctGPU memory controller utilization (%)
memory_used_mibGPU memory used (MiB)
memory_total_mibGPU memory total (MiB)
temperature_cGPU temperature (Celsius)
power_draw_wCurrent power draw (Watts)
clock_sm_mhzStreaming multiprocessor clock (MHz)
clock_mem_mhzMemory clock (MHz)
Per-Execution I/O Sample Files
When io_sampling is enabled, each execution produces one I/O sample CSV per node:
Location: workdir/run_001/exec_0001/repetition_001/__iops_io_trace_<hostname>_<attempt_id>.csv
Format:
timestamp,hostname,source,device,path,interval_s,read_bytes,write_bytes,read_ops,write_ops
1705123457.1,node01,block,nvme0n1,/scratch/run,1.002,0,536870912,0,4096
1705123457.1,node01,nfs,server:/export,/data/input,1.002,104857600,0,800,0
Fields:
FieldDescription
sourceCounter source: block or nfs
deviceBlock device name (nvme0n1) or NFS mount source (server:/export)
pathThe configured io_paths entry this row was resolved from, empty when no paths were configured
interval_sSeconds this row covers, measured rather than assumed
read_bytesBytes read during the interval
write_bytesBytes written during the interval
read_opsRead operations during the interval
write_opsWrite operations during the interval
Values are per-interval deltas, not cumulative counters. The first sample of a run establishes the baseline and emits no row. A counter that goes backwards (a reset or a wrap) is clamped to zero rather than emitting a spurious burst. interval_s is recorded because sleep drifts under load, so rates computed from it are more accurate than rates assuming the configured interval.
Per-Execution I/O Targets Files
When io_paths is set, each node records what the configured paths resolved to:
Location: workdir/run_001/exec_0001/repetition_001/__iops_io_targets_<hostname>_<attempt_id>.json
  "hostname": "node01",
  "paths": [
    {"path": "/scratch/run", "kind": "block", "target": "nvme0n1", "mount": "/scratch", "fstype": "ext4"},
    {"path": "/dev/shm/cache", "kind": "none", "target": "", "mount": "/dev/shm", "fstype": "tmpfs"}
kind is block, nfs, or none when the filesystem has no counters to read. One file per node, because the same path can resolve differently across an allocation. This is the first thing to check when an I/O metric reads zero.
Run-Level Summary
After all executions complete, IOPS aggregates samples into a summary CSV:
This file contains one row per execution+repetition, with all user variables and aggregated metrics from the CPU/memory, GPU, and I/O samplers (whichever are enabled), enabling correlation analysis between parameter configurations and resource footprint.
Columns are the union across all executions. An execution short enough that its sampler collected no usable samples reports only the counter columns, and the remaining cells are left empty.
CPU/Memory Aggregated Metrics
Metrics are computed from all samples across all nodes. A sample is one row in the CSV: a single measurement at a specific timestamp for a specific core on a specific node.
The following intermediate values are computed per sample:
  • mem_used = mem_total_kb - mem_available_kb (memory used)
  • cpu_total = cpu_user_pct + cpu_system_pct (CPU utilization)
MetricDescriptionFormula
mem_peak_gbMaximum memory used across all samplesmax(mem_used) / 1024²
mem_avg_gbAverage memory across all samplessum(mem_used) / count(samples) / 1024²
mem_peak_per_node_gbHighest per-node peak memorymax(max(mem_used) per node) / 1024²
cpu_avg_pctAverage CPU utilizationsum(cpu_total) / count(samples)
cpu_max_pctPeak CPU utilizationmax(cpu_total)
cpu_imbalance_pctLoad balancing indicatormax(max(cpu_total) per core) - min(max(cpu_total) per core)
nodes_tracedNumber of nodes with trace datacount(distinct hostname)
samples_collectedTotal samples across all nodescount(rows)
trace_duration_sTime span of trace datamax(timestamp) - min(timestamp)
GPU Aggregated Metrics
When gpu_sampling is enabled, GPU metrics are added to the summary CSV. Metrics are computed per GPU first, then aggregated across GPUs. This prevents idle GPUs from dragging down the averages on multi-GPU machines where only a subset of GPUs is active.
Per-GPU Columns
Each GPU gets its own set of columns in the summary CSV, named by device index:
Column patternExampleDescription
gpuN_avg_utilization_pctgpu0_avg_utilization_pctAverage utilization for GPU N
gpuN_avg_power_wgpu0_avg_power_wAverage power draw for GPU N
gpuN_energy_jgpu0_energy_jEnergy consumed by GPU N (Joules)
gpuN_avg_temperature_cgpu0_avg_temperature_cAverage temperature for GPU N
gpuN_mem_peak_mibgpu0_mem_peak_mibPeak memory used by GPU N
When traces span multiple nodes (multi-node runs, or a rescheduled job that left a partial trace on a previous host), the hostname is added as a prefix so same-indexed GPUs on different hosts do not collide: node01_gpu0_*, node01_gpu1_*, node02_gpu0_*, and so on. Single-node runs keep the plain gpuN_* naming.
Aggregate Columns
Aggregate metrics use the maximum of per-GPU averages so that idle GPUs do not dilute the stats. For example, if GPU 0 averages 90% utilization and GPU 1 is idle at 0%, gpu_avg_utilization_pct reports 90%, not 45%.
MetricDescriptionAggregation
gpu_countNumber of distinct GPUs sampledcount(distinct hostname:gpu_index)
gpu_avg_utilization_pctBest per-GPU average utilizationmax(per-GPU avg utilization)
gpu_max_utilization_pctPeak instantaneous utilizationmax(all samples)
gpu_avg_mem_utilization_pctBest per-GPU average memory utilizationmax(per-GPU avg mem utilization)
gpu_mem_peak_mibPeak GPU memory usedmax(all per-GPU peaks)
gpu_avg_temperature_cHighest per-GPU average temperaturemax(per-GPU avg temperature)
gpu_max_temperature_cPeak instantaneous temperaturemax(all samples)
gpu_avg_power_wHighest per-GPU average powermax(per-GPU avg power)
gpu_max_power_wPeak instantaneous powermax(all samples)
gpu_energy_jTotal energy consumed (Joules)sum(per-GPU energy)
gpu_trace_duration_sTime span of GPU sample datamax(timestamp) - min(timestamp)
gpu_samples_collectedTotal GPU samplescount(rows)
Energy Calculation
The gpu_energy_j metric provides total GPU energy consumption in Joules. Energy is computed per GPU by integrating instantaneous power draw over time using the trapezoidal rule (E_interval = (P_i + P_{i+1}) / 2 * (t_{i+1} - t_i) for consecutive samples), then summed across all GPUs. This gives accurate results even with varying power draw. Per-GPU energy is available via gpu0_energy_j, gpu1_energy_j, etc. To convert to kilowatt-hours: kWh = gpu_energy_j / 3600000.
I/O Aggregated Metrics
When io_sampling is enabled, I/O metrics are added to the summary CSV. Byte totals sum the per-interval deltas across every device, source, and node. Volumes use 1024-based units, matching the memory metrics.
duration below is the elapsed time a single node covered, summed over its samples. Using the first and last timestamps instead would drop the window between the baseline and the first emitted row.
io_read_gbTotal read across all sourcessum(read_bytes) / 1024³
io_write_gbTotal written across all sourcessum(write_bytes) / 1024³
io_disk_read_gbRead from block devicessum(read_bytes where source = block) / 1024³
io_disk_write_gbWritten to block devicessum(write_bytes where source = block) / 1024³
io_nfs_read_gbRead from NFS mountssum(read_bytes where source = nfs) / 1024³
io_nfs_write_gbWritten to NFS mountssum(write_bytes where source = nfs) / 1024³
io_read_mbs_avgAggregate read throughput over the whole runsum(read_bytes) / 1024² / duration
io_write_mbs_avgAggregate write throughput over the whole runsum(write_bytes) / 1024² / duration
io_read_mbs_activeRead throughput while the storage was workingsum(read_bytes) / 1024² / io_read_active_s
io_write_mbs_activeWrite throughput while the storage was workingsum(write_bytes) / 1024² / io_write_active_s
io_read_active_sTime any read was in flightmax(sum(interval_s) where read_bytes > 0, per node)
io_write_active_sTime any write was in flightmax(sum(interval_s) where write_bytes > 0, per node)
io_read_mbs_peak_per_nodeBusiest single read sample on any nodemax(sum(read_bytes) per node-instant / interval_s) / 1024²
io_write_mbs_peak_per_nodeBusiest single write sample on any nodemax(sum(write_bytes) per node-instant / interval_s) / 1024²
io_read_iops_avgAverage read operations per secondsum(read_ops) / duration
io_write_iops_avgAverage write operations per secondsum(write_ops) / duration
io_nodes_tracedNumber of nodes with I/O sample datacount(distinct hostname)
io_samples_collectedSampling instants across all nodescount(distinct hostname + timestamp)
io_trace_duration_sElapsed time coveredmax(sum(interval_s) per node)
The averages are aggregate: they sum every node’s traffic over the elapsed window, which is the number a storage study wants. The peaks are per node, because samples on different nodes are not clock-aligned and adding them at a supposedly shared instant would be fiction.
The disk and NFS columns are always emitted, holding zero when that source saw no traffic, so a run comparing the two backends produces a complete table either way.
Idle samples and what they do to each metric
Sampling covers the whole script, and most benchmarks spend much of that doing something other than I/O: loading modules, starting MPI, computing. Those intervals are recorded as zero-byte samples, and they are load-bearing, since they are what makes io_trace_duration_s the real elapsed window.
They affect the metrics differently:
Metric familyAffected by idle samplesWhy
Volumes (io_read_gb, io_write_gb, and the per-source splits)NoSums, and adding zero changes nothing
Peaks (io_*_mbs_peak_per_node)NoA maximum over samples, so idle ones are ignored
io_*_mbs_avg, io_*_iops_avgYesDivided by the whole window, so idle time pulls them down
io_*_mbs_activeNoDivided by the time that direction actually moved data
Both averages are reported because they answer different questions. io_write_mbs_avg is what the job moved per second of runtime; io_write_mbs_active is how fast the storage went while in use. A job that computes for ten minutes and writes for ten seconds will show an io_write_mbs_avg roughly sixty times lower than its io_write_mbs_active, and neither number is wrong. Compare io_write_active_s against io_trace_duration_s to see the duty cycle.
Quote io_*_mbs_active when characterising storage, and io_*_mbs_avg when characterising the job.
Short executions undersample. If a test finishes in less time than a few sampling intervals, the totals cover only the intervals that were observed and will read low. Lower sampling_interval for short tests, or treat the volumes as a lower bound.
Configuration Reference
benchmark:
  probes:
    # Enable CPU/memory sampling (default: false)
    # Enable GPU sampling (default: false)
    # Currently supports NVIDIA GPUs (via nvidia-smi)
    # Gracefully skips if no supported GPU is detected
    gpu_sampling: true
    # Enable I/O sampling (default: false)
    # Reads block device counters (/proc/diskstats) and NFS client
    # counters (/proc/self/mountstats), reporting each source separately
    io_sampling: true
    # Required with io_sampling: the storage behind these paths is what
    # gets measured. Jinja2 templates, rendered per execution, resolved on
    # the compute node.
    io_paths:
      - "/scratch/input"
    # Sampling interval in seconds (default: 1.0)
    # Shared by resource_sampling, gpu_sampling and io_sampling
    # Lower = finer granularity but more data
    sampling_interval: 0.5
Multi-Node Support
For multi-node jobs, IOPS automatically launches samplers on all allocated nodes. A shared node launcher (__iops_node_launcher.sh) resolves the job’s node list and starts one sampler per node:
SchedulerNode listLaunch method
SLURMscontrol show hostnames $SLURM_JOB_NODELISTsrun --overlap --ntasks-per-node=1 (one call covers the allocation)
OAR$OAR_NODEFILEoarsh per remote node
PBS$PBS_NODEFILEssh per remote node
None detectedlocal hostnamebackground process on the local node
All samplers share the same sentinel file on the shared filesystem; when the exit handler removes it, all node samplers stop.
Each node produces its own sample files (__iops_trace_node01_<attempt_id>.csv, __iops_gpu_trace_node01_<attempt_id>.csv, etc.), and the aggregation combines data from all nodes. The CPU/memory sampler and the GPU sampler support multi-node operation independently.
Two requirements for remote sampling to produce data:
  1. The execution directory must be on a filesystem shared by all nodes, since remote samplers write their traces there. When it is node-local the benchmark still runs, only the remote traces stay behind on their nodes.
  2. Passwordless remote access must work between compute nodes (oarsh or ssh in batch mode), which is the default on most clusters.
Check nodes_traced in __iops_resource_summary.csv to confirm how many nodes were actually sampled. A value of 1 on a multi-node run means only the head node reported.
Fault Tolerance
Resource sampling is designed to never break your benchmark:
  • All sampler commands use || true to suppress errors
  • Missing or malformed sample files are skipped during aggregation
  • If no sample files exist, the summary is simply not created
  • The GPU sampler gracefully skips if no supported GPU vendor is detected (no errors, no empty files)
  • The I/O sampler gracefully skips when neither counter source is readable (for example on a non-Linux host), and when every configured path resolves to storage with no counters
I/O Considerations
Sample files are written to the execution directory. For benchmarks testing storage performance, place workdir on a separate filesystem from the test target, or accept the minimal I/O overhead (one CSV append per sample interval). The sampler uses buffered writes and runs at lowest scheduling priority to minimize impact.
