Writing Parsers
IOPS does not know the output format of your benchmark. Instead, you provide a small Python script (the parser) that reads whatever your benchmark produces and returns the metrics you care about. This page explains how parsers work, how to write one, and where the extracted data ends up.
How It Works
Every benchmark writes its results differently: JSON files, plain text logs, CSV tables, binary formats. The parser is the bridge between raw benchmark output and structured data that IOPS can store, plot, and analyze. After each execution completes, IOPS runs it through this sequence:
  1. Locate the output file using the parser.file path (resolved with Jinja2)
  2. Load your parser script and inject execution context as Python globals
  3. Call your parse(file_path) function with the resolved file path
  4. Validate the result, checking that all declared metrics are present
  5. Store the metrics alongside the execution parameters in the configured output sink
Configuration
The parser is defined inside the scripts[] section of your YAML configuration:
scripts:
  - name: "my_benchmark"
    submit: "bash"
    script_template: |
      #!/bin/bash
      ./my_benchmark --output {{ execution_dir }}/results.json
    parser:
      file: "{{ execution_dir }}/results.json"
      metrics:
        - name: throughput
        - name: latency
      parser_script: |
        import json
        def parse(file_path):
            with open(file_path) as f:
                data = json.load(f)
            return {
                "throughput": data["bw_mb"],
                "latency": data["avg_latency_ms"]
Fields
FieldRequiredDescription
fileYesPath to the output file. Supports Jinja2 (e.g., {{ execution_dir }}/output.txt).
metricsYesList of metric names to extract. Each entry has a name field.
parser_scriptYesInline Python code or path to an external .py file.
Writing the parse() Function
Rules
  • The function must be named parse and accept exactly one positional argument
  • It must return a dict with keys matching every metric declared in metrics
  • Values can be numeric (int, float) or None if the metric could not be extracted
  • You can return extra keys beyond the declared metrics (they will be ignored)
  • You can import any module available in your Python environment
  • The script itself is not Jinja2-templated; use context globals instead (see below)
Minimal Example
        value = float(f.read().strip())
    return {"throughput": value}
Context Variables
Your parser script has access to execution context through Python global variables, injected before your script runs. Use them directly, without imports or arguments.
VariableTypeDescription
varsdictAll execution variables (e.g., vars["nodes"], vars["block_size"])
envdictRendered command.env variables
os_envdictSystem environment variables (e.g., os_env["HOME"])
execution_idstrExecution identifier (e.g., "exec_0001")
execution_dirstrPath to the execution directory
workdirstrRoot working directory path
log_dirstrLogs directory path
repetitionintCurrent repetition number
repetitionsintTotal number of repetitions
metricslistList of declared metric names
Examples
JSON Output (I/O Benchmark)
A benchmark writes performance results as JSON:
parser:
  metrics:
    - name: bandwidth
    - name: iops
  parser_script: |
    import json
            data = json.load(f)
        return {
            "bandwidth": data["bw_MiBps"],
            "iops": data["iops"]
Plain Text with Regex (Simulation)
A simulation prints results mixed with log messages:
[INFO] Starting simulation...
[INFO] Grid size: 256x256
[RESULT] Elapsed time: 12.453 seconds
[RESULT] Iterations: 5000
[RESULT] GFLOPS: 42.7
parser:
  file: "{{ execution_dir }}/simulation.log"
  metrics:
    - name: elapsed_time
    - name: gflops
  parser_script: |
    import re
            content = f.read()
        time = float(re.search(r"Elapsed time: ([\d.]+)", content).group(1))
        gflops = float(re.search(r"GFLOPS: ([\d.]+)", content).group(1))
        return {"elapsed_time": time, "gflops": gflops}
The same pattern works for any format your benchmark produces (CSV via csv.DictReader, XML, binary, …): open the file, extract values, return the dict.
Using Context Variables (Derived Metrics)
Compute per-node throughput using the vars global. The same pattern supports conditional logic, e.g. picking a different JSON field when vars["operation"] == "write":
parser:
  file: "{{ execution_dir }}/output.json"
  metrics:
    - name: total_bandwidth
    - name: bandwidth_per_node
  parser_script: |
    import json
            data = json.load(f)
        total = data["bandwidth_mb"]
        return {
            "total_bandwidth": total,
            "bandwidth_per_node": total / vars["nodes"]
External Parser File
For complex parsers, keep the script in a separate .py file instead of inlining it. The file has the same structure and access to the same context globals:
parser:
  metrics:
    - name: throughput
  parser_script: ./scripts/my_parser.py
Where the Data Goes
After parsing, IOPS combines your metrics with the execution parameters and writes everything to the configured output sink (output.sink, formats: csv, parquet, sqlite). Each row in the results file contains:
CategoryFields
Execution infoexecution_id, repetition
Benchmark infobenchmark.name, benchmark.description
ParametersAll variables from the vars section
Your metricsEvery metric returned by your parse() function
MetadataStatus, timing, job IDs (depending on executor)
The results file feeds iops report for HTML reports and can be loaded directly for custom analysis with tools like pandas or R.
Debugging
When a parser fails, IOPS captures diagnostic output to help you investigate:
  • stdout/stderr from your script are saved to parser_stdout and parser_stderr files in the execution directory
  • The execution status is set to ERROR with a message describing the failure
  • Use iops find /path/to/workdir --status ERROR to locate failed executions
Common issues:
ProblemCauseFix
ParserContractError: no parse() functionMissing or misspelled functionEnsure your script defines def parse(file_path):
ParserContractError: expected dictparse() returns wrong typeReturn a dictionary, not a list or scalar
Missing metric "X"Return dict missing a declared metricEnsure every name in metrics appears as a key in the returned dict
FileNotFoundErrorOutput file path is wrongCheck the file path, use --dry-run to preview resolved paths
KeyError / IndexErrorUnexpected output formatAdd print statements for debugging; check parser_stdout
Tips
  • Start simple. Test your parser on a single output file before integrating it into the YAML.
  • Use print() for debugging. Anything printed during parsing is captured in parser_stdout.
  • Return None for missing metrics instead of raising an exception; this keeps the rest of the study intact.
  • Keep parsers focused. Extract numbers from a file; avoid heavy computation or side effects.
  • Use external files for complex parsers. Past ~20 lines, move to a separate .py file for easier editing and testing.
