Writing Scripts
The scripts[] section of your YAML tells IOPS how to launch your benchmark. IOPS owns the parameter sweep and the result database; you own the shell script that actually runs the workload. This page is the practical guide to writing scripts; for the schema (every field, every option), see YAML Schema Reference / scripts.
Why You Need a Script Template
IOPS does not assume anything about how your benchmark is launched: some benchmarks are a single executable, others need MPI launchers, module loads, environment setup, or pre-flight checks. The script_template is the bridge: a Jinja2-rendered shell script that IOPS materializes to disk and hands to the configured executor. Per test execution, IOPS writes it to <execution_dir>/run_<name>.sh so you can inspect (or rerun) exactly what was executed.
How It Works
For each test execution, IOPS goes through this sequence:
  1. Resolve variables for the current execution (sweep vars, derived vars, conditional vars)
  2. Render input files declared in inputs: (see Generating Input Files)
  3. Render the script template with the full execution context
  4. Inject IOPS helper scripts (system probe, resource sampler, exit handler) if enabled
  5. Write the script to <execution_dir>/repetition_NNN/run_<name>.sh
  6. Submit it with the executor (bash locally, sbatch on SLURM)
  7. Wait for completion, capture stdout / stderr
  8. Run the parser (and the optional post.script)
Each repetition gets its own folder with its own script, so different repetitions of the same test can be inspected independently.
Configuration
Scripts live under the top-level scripts: list:
scripts:
  - name: "ior_write"
    submit: "bash"                  # or "sbatch" for SLURM (defaults from executor)
    script_template: |
      #!/bin/bash
      module load mpi
      mpirun -np {{ ntasks }} {{ command.template }}
    inputs: []                      # optional, see "Generating Input Files"
    post: { script: ... }           # optional, post-execution hook
    parser: { ... }                 # see "Writing Parsers" guide
Fields
FieldRequiredDescription
nameYesIdentifier used in generated filenames (run_<name>.sh).
script_templateYesInline shell script body (Jinja2-rendered) or path to an external file.
submitNoSubmission command. Defaults to bash for local executor, sbatch for SLURM.
inputsNoDeclarative parameter files generated before the script runs.
postNoPost-execution script (cleanup, summaries).
parserYesHow to extract metrics from output (see Writing Parsers).
You can define multiple scripts in the list; each one produces an independent test for every parameter combination.
Writing the script_template
A script template is a regular shell script with {{ var }} placeholders. There is no required structure beyond what your benchmark needs, but a few habits make scripts easier to debug:
Anatomy of a Good Script
#!/bin/bash
# 1. SLURM directives (only when executor: "slurm")
#SBATCH --nodes={{ nodes }}
#SBATCH --ntasks={{ ntasks }}
#SBATCH --time=01:00:00
#SBATCH --chdir={{ execution_dir }}
#SBATCH -o batch%j.out
#SBATCH -e batch%j.err
# 2. Fail fast
set -euo pipefail
# 3. Environment
module purge
module load mpi/openmpi/4.1
export OMP_NUM_THREADS={{ processes_per_node }}
# 4. Logging
echo "=== Execution {{ execution_id }} rep {{ repetition }}/{{ repetitions }} ==="
echo "Nodes: $SLURM_JOB_NUM_NODES, Tasks: $SLURM_NTASKS"
# 5. Run the benchmark
This layout works well because SLURM directives must come first (parsed by sbatch before anything runs), set -euo pipefail catches failures early, explicit modules and env vars make the environment reproducible, and logging the resolved parameters helps when a specific test misbehaves.
Rules
  • The shell language is yours to choose (#!/bin/bash, #!/bin/zsh, #!/usr/bin/env python3, anything submit can execute)
  • {{ }} placeholders are rendered before the script is written; the running shell never sees Jinja2
  • Lines starting with #SBATCH are ignored by bash but parsed by sbatch, so you can leave them in a local-executor script if you sometimes switch executors
  • The script’s working directory at runtime is not guaranteed to be the execution directory; use {{ execution_dir }} for absolute paths instead of relying on cwd
Context Variables
The full execution context is injected into the Jinja2 template: all declared vars, execution_id, repetition, repetitions, execution_dir (per-repetition output directory, where run_*.sh lives), workdir, log_dir, os_env, command.template (the rendered benchmark command), command_env, command_labels, and inputs ({{ inputs.<name>.path }}, see below).
The complete table with examples lives in Templating and Context / scripts[].script_template; for Jinja2 syntax itself (conditionals, loops, filters), see Templating and Context / Jinja2 Syntax.
Including the Benchmark Command
command.template is the benchmark invocation defined separately under command:. Reusing it inside the script keeps the command in one place:
command:
  template: "ior -w -b {{ block_size_mb }}mb -t 1mb -o {{ execution_dir }}/data.ior"
scripts:
  - name: "ior_write"
    script_template: |
      #!/bin/bash
      module load mpi ior
{{ command.template }} expands to the fully rendered string. Do not repeat arguments that are already in the template; doing so usually duplicates flags and produces confusing failures.
Many benchmarks read their parameters from a config file rather than the command line. The inputs: field generates these files at preparation time, alongside the script:
scripts:
  - name: "io500"
    inputs:
      - name: config_ini
        path: "{{ execution_dir }}/config.ini"
        template: |
          [global]
          datadir = {{ os_env.SCRATCH }}/io500_data
          api = POSIX
          [ior-easy]
          blockSize = {{ block_size_gb }}g
          transferSize = 2m
    script_template: |
      #!/bin/bash
      ./io500 {{ inputs.config_ini.path }}
The file is written before the script runs and stays on disk even if the script aborts, so you can always check what input a particular execution actually received. See YAML Schema / inputs for the full reference.
Post-Execution Scripts
post.script runs after the main script finishes (success or failure). Use it for cleanup, summaries, or moving result files out of $TMPDIR:
scripts:
  - name: "ior"
    script_template: |
      #!/bin/bash
      ior -w -o $TMPDIR/data.ior > {{ execution_dir }}/summary.txt
    post:
      script: |
        #!/bin/bash
        echo "Cleanup at $(date)"
        rm -f $TMPDIR/data.ior
        ls -lh {{ execution_dir }}
The post script receives the same Jinja2 context as script_template, including {{ inputs.<name>.path }} references, and runs with the same executor as the main script.
External Script Files
For long or shared scripts, point script_template at a file instead of inlining the body:
scripts:
  - name: "ior"
    script_template: ./scripts/run_ior.sh
    parser: { ... }
The file is resolved relative to the YAML, loaded at config-load time, then rendered with Jinja2 the same way an inline string would be. The same external-file shortcut works for post.script and parser.parser_script.
Examples
Local Executor: Single Binary
benchmark:
  executor: "local"
scripts:
  - name: "stream"
    script_template: |
      #!/bin/bash
      set -euo pipefail
      export OMP_NUM_THREADS={{ threads }}
      ./stream_c.exe > {{ execution_dir }}/stream.out
    parser:
      file: "{{ execution_dir }}/stream.out"
      metrics: [{ name: bandwidth }]
      parser_script: |
        import re
        def parse(file_path):
            content = open(file_path).read()
            return {"bandwidth": float(re.search(r"Triad:\s+([\d.]+)", content).group(1))}
For a SLURM MPI job, see the anatomy script above: set executor: "slurm" and keep the #SBATCH directives.
Conditional Directives (Different Resource Tiers)
scripts:
  - name: "ior"
    script_template: |
      #!/bin/bash
      {% if nodes > 16 %}
      #SBATCH --time=04:00:00
      #SBATCH --partition=large
      {% else %}
      #SBATCH --partition=batch
      {% endif %}
      srun {{ command.template }}
Note the required spaces inside {% %}: {%if%} raises a TemplateSyntaxError.
Reusing a Script Across Machines
A single script_template plus a machines: block lets the same study run on a laptop and a cluster (see Machine Overrides):
scripts:
  - name: "ior"
    script_template: |
      #!/bin/bash
      module load mpi ior
machines:
  laptop:
    benchmark:
      executor: "local"
      repetitions: 1
  cluster:
    benchmark:
      executor: "slurm"
      repetitions: 5
    scripts:
      - name: "ior"        # override merges by name
        script_template: |
          #!/bin/bash
          module load mpi ior
Single-Allocation Mode
When slurm_options.allocation.mode: "single", IOPS submits one SLURM job and runs every test inside that allocation via srun --jobid=<id> --overlap. The implications for script_template:
  • Drop the #SBATCH directives: resources are controlled by slurm_options.allocation.allocation_script
  • Load modules inside the script: each srun starts a fresh shell
  • For MPI programs, use srun directly with the variables (no mpirun wrapper needed)
See Single-Allocation Mode for the full picture and a complete example.
Where Script Artifacts Go
After execution, every test directory contains a complete record of what ran:
<workdir>/run_001/runs/exec_0001/
├── __iops_params.json            # Resolved parameter values for this execution
└── repetition_001/
    ├── run_<name>.sh             # The rendered main script
    ├── post_<name>.sh            # The rendered post script (if any)
    ├── <files from inputs:>      # Input files generated by the inputs: block
    ├── stdout                    # Captured script stdout
    ├── stderr                    # Captured script stderr
    ├── batch<jobid>.out          # SLURM stdout (SLURM only)
    ├── batch<jobid>.err          # SLURM stderr (SLURM only)
    ├── __iops_status.json        # Execution status (SUCCEEDED, FAILED, ...)
    └── __iops_sysinfo.json       # System info (if system_snapshot probe is on)
run_<name>.sh is the exact, fully rendered script that ran (no {{ }} placeholders). You can rerun it by hand to reproduce a failure: cd repetition_001 && bash run_<name>.sh.
Debugging
SymptomWhere to lookCommon cause
TemplateSyntaxError on loadLoader error messageMissing space in {% if cond %}, mismatched {% endif %}
UndefinedError: 'X' is undefinedLoader or runtime errorVariable not in vars:, or referenced before it’s available
Script not executable / wrong shellstderr, batch*.errMissing or wrong shebang; submit: mismatched with shebang
SLURM #SBATCH ignoredJob submitted but no resource limitsLines before the shebang, or extra blank lines splitting the directive block
Job runs but writes nothingstderr, __iops_status.jsonset -e not enabled; module load silently failed
Parameters look wrong__iops_params.json, top of run_<name>.shDerived variable expression has the wrong precedence
Input file missing at runtime<execution_dir>/repetition_001/Forgot inputs: entry, or path: rendered to an unexpected location
A few practical commands:
# Validate the config without running anything
iops check my_study.yaml
# Show what each test would do (resolved variables, command, cache lookups)
iops run my_study.yaml --dry-run
# Inspect failed executions
iops find ./workdir/run_001 --status FAILED
# Rerun a single failed test
cd ./workdir/run_001/runs/exec_0017/repetition_001 && bash run_ior.sh
Tips
  • Start with iops check and --dry-run. They catch most YAML and template mistakes before any job goes out.
  • Use set -euo pipefail. A silent module-load failure that leaves the benchmark unrun is far more painful than a loud error.
  • Capture parameters at the top of the script (echo "nodes={{ nodes }} ppn={{ processes_per_node }}") so the values are right there when you scan logs later.
  • Use absolute paths via {{ execution_dir }}. Don’t rely on the script’s working directory being anywhere in particular.
  • Don’t put iops-specific logic in the script. IOPS injects what it needs (probes, samplers) automatically.
  • Externalize long scripts. Past ~30 lines, move the body into a .sh file (script_template: ./scripts/run.sh) for easier linting and testing.
