IOPS YAML Format Reference
Complete guide to the IOPS benchmark configuration format
Table of Contents
  1. File Structure Overview
  2. benchmark
  3. vars
  4. constraints (optional)
  5. command
  6. scripts
  7. output
  8. reporting (optional)
  9. hooks (optional)
  10. machines (optional)
See also: Templating and Context Reference for Jinja2 syntax, dynamic values, conditionals, and context variables.
benchmark:       # Global configuration (name, workdir, executor, search method)
vars:            # Variable definitions (swept and derived)
constraints:     # (Optional) Parameter validation rules
command:         # Command template and labels
scripts:         # Execution scripts and parsers
output:          # Output configuration (CSV, Parquet, SQLite)
reporting:       # (Optional) Report generation settings
hooks:           # (Optional) Commands fired on run events
machines:        # (Optional) Per-machine config overrides
Required sections: benchmark, vars, command, scripts, output
benchmark
Defines global benchmark configuration.
benchmark:
  name: string                      # Required: benchmark name
  workdir: path                     # Required: base working directory
  description: string               # Optional: human-readable description
  repetitions: integer              # Optional: repetitions per test (default: 1)
  search_method: string             # Optional: "exhaustive" | "random" | "bayesian" | "adaptive"
  random_config:                    # Required if search_method: "random"
    n_samples: integer              #   Sample exactly N configurations
    percentage: float               #   OR sample percentage of parameter space
    fallback_to_exhaustive: boolean #   Use full space if sample >= total (default: true)
  bayesian_config:                  # Required if search_method: "bayesian"
    objective_metric: string        #   Required: metric to optimize
    objective: string               #   "minimize" | "maximize" (default: "minimize")
    fallback_to_exhaustive: boolean #   Use exhaustive if n_iterations >= total space (default: true)
    n_iterations: integer           #   Total evaluations (default: 20)
    n_initial_points: integer       #   Random samples before optimization (default: 5)
    acquisition_func: string        #   "EI" | "PI" | "LCB" (default: "EI")
    base_estimator: string          #   "RF" | "GP" | "ET" | "GBRT" (default: "RF")
    xi: float                       #   Exploration trade-off for EI/PI (default: 0.01)
    kappa: float                    #   Exploration parameter for LCB (default: 1.96)
    early_stop_on_convergence: bool #   Stop when optimizer converges (default: false)
    convergence_patience: integer   #   Convergences before early stop (default: 3)
    xi_boost_factor: float          #   xi multiplier when stuck (default: 5.0)
    max_retries: integer            #   Re-asks per iteration on a visited point before random fallback (default: 10)
  executor: string                  # Optional: "local" | "slurm" (default: "slurm")
  slurm_options:                 # Optional: SLURM-specific configuration
    commands:                       #   SLURM command templates
      submit: string                #     Submit command (default: "sbatch")
      status: string                #     Status template (default: "squeue -j {job_id} ...")
      info: string                  #     Info template (default: "scontrol show job {job_id}")
      cancel: string                #     Cancel template (default: "scancel {job_id}")
    poll_interval: integer          #   Status polling interval in seconds (default: 30)
    allocation:                     #   Single-allocation mode (SLURM only)
      mode: string                  #     "single" | "per-test" (default: "per-test")
      allocation_script: string     #     SBATCH directives for allocation (required if mode: "single")
      test_timeout: integer         #     Per-test timeout in seconds (default: 3600)
  random_seed: integer              # Optional: seed for randomization (default: 42)
  cache_file: path                  # Optional: cache file location
  cache_exclude_vars: list          # Optional: vars to exclude from cache hash
  probes:                           # Optional: probe configuration
    system_snapshot: boolean        #   Collect system info (default: true)
    execution_index: boolean        #   Write metadata files (default: true)
    resource_sampling: boolean      #   Enable CPU/memory sampling (default: false)
    gpu_sampling: boolean           #   Enable GPU metrics tracing (default: false)
    io_sampling: boolean            #   Enable I/O tracing (default: false)
    io_paths: [string]              #   Required with io_sampling: what storage to measure
    sampling_interval: float        #   Sampling interval in seconds (default: 1.0)
    versions:                       #   Optional: capture software/library versions
      component_name: string        #   name -> shell command (e.g. "myapp --version")
  parallel: integer                 # Optional: max concurrent tests (default: 1)
  create_folders_upfront: boolean   # Optional: create all folders at start (default: false)
  exhaustive_vars: list             # Optional: vars to test exhaustively
  report_vars: list                 # Optional: vars to include in reports
  max_core_hours: float             # Optional: CPU core-hours budget limit
  cores_expr: string                # Optional: Jinja expression for cores (default: "1")
  estimated_time_seconds: float     # Optional: estimated test duration (seconds)
name (required)
Human-readable benchmark name. Used in logs and output.
workdir (required)
Base directory for all benchmark outputs. Supports environment variables. Created automatically on first run if it does not exist.
repetitions (optional, default: 1)
Number of times each test is repeated.
search_method (optional, default: “exhaustive”)
Test selection strategy: exhaustive, random, bayesian, or adaptive. See Adaptive Variables for the adaptive method.
random_config (required if search_method: "random")
  • n_samples and percentage are mutually exclusive
  • percentage is a fraction between 0 and 1 (e.g., 0.5 samples 50% of the space); values above 1.0 are rejected
bayesian_config (required if search_method: "bayesian")
Default values are empirically tuned: with 20 iterations (~7% of search space), Bayesian optimization achieves ~90% of optimal vs ~79% for random search.
Options:
  • fallback_to_exhaustive (default: true): switches to exhaustive search when n_iterations >= total_space_size, avoiding optimizer overhead for small parameter spaces.
  • early_stop_on_convergence (default: false): when the optimizer converges (keeps suggesting already-visited configurations), xi is boosted by xi_boost_factor (default: 5.0) to encourage exploration and escape local optima; after convergence_patience (default: 3) consecutive convergences, the run stops early.
  • max_retries (default: 10): how many times per iteration the optimizer is re-asked when its suggestion maps to an already-visited point before falling back to random sampling from unvisited points. Each retry refits the surrogate model, so lower values (e.g. 2-3) speed up large n_iterations runs where suggestions frequently collide.
Surrogate models:
  • RF: Random Forest (default) - most consistent results, handles categorical/mixed spaces well
  • ET: Extra Trees - similar to RF, slightly higher variance
  • GP: Gaussian Process - best for continuous spaces, struggles with categoricals
  • GBRT: Gradient Boosted Regression Trees
executor (optional, default: “slurm”)
Execution backend: local or slurm.
slurm_options (optional, SLURM only)
commands customizes the SLURM command templates (see defaults in the schema above); the {job_id} placeholder is replaced at runtime. Useful for systems with command wrappers or custom SLURM installations.
Single-Allocation Mode:
Run all tests within ONE SLURM allocation instead of submitting individual jobs per test:
benchmark:
  executor: "slurm"
  slurm_options:
    allocation:
      mode: "single"
      test_timeout: 300  # 5 minutes per test (default: 3600)
      allocation_script: |
        #SBATCH --nodes=8
        #SBATCH --time=02:00:00
        #SBATCH --partition=batch
        #SBATCH --account=myaccount
        #SBATCH --exclusive
When to use: HPC systems with job limits, long queue wait times, or many small tests.
See Single-Allocation Mode for details.
random_seed (optional, default: 42)
Seed for random operations (repetition interleaving, random/bayesian sampling).
cache_file (optional)
Path to cache file. Required for --use-cache flag.
cache_exclude_vars (optional)
Variables to exclude from cache hash (e.g., path-based derived variables).
probes (optional)
Configuration for IOPS probes (system monitoring and execution tracking):
FieldDefaultDescription
system_snapshottrueCollect hardware/environment info from compute nodes
execution_indextrueWrite metadata files for iops find command
resource_samplingfalseEnable CPU and memory sampling during execution. See Resource Sampling
gpu_samplingfalseEnable GPU metrics sampling (utilization, power, temperature, memory, clocks). Supports NVIDIA GPUs via nvidia-smi. See Resource Sampling
io_samplingfalseEnable I/O sampling (bytes and operations read and written). Reads block device counters and NFS client counters, reported separately. See Resource Sampling
io_paths(required with io_sampling)The filesystems holding these paths are what gets measured, e.g. ["{{ execution_dir }}"]. Jinja2 templates rendered per execution and resolved on the compute node. Requires io_sampling: true. See Resource Sampling
sampling_interval1.0Sampling interval in seconds for resource and GPU sampling
versionsnoneCapture software/library versions per execution. Mapping of component name to shell command. Captured after the benchmark body (via the exit handler, so tools loaded by the benchmark’s own module load commands are in scope) into __iops_versions.json, and also written to the results sink as version.<component> columns. The HTML report shows a drift warning when versions differ across executions.
create_folders_upfront (optional, default: false)
Create all execution folders at run start instead of lazily during execution.
When enabled, all exec_XXXX folders exist before execution begins and tests skipped by constraints or planner selection get a SKIPPED status, giving full visibility into the parameter space (useful for debugging constraints and planner behavior). When disabled, folders are created lazily and skipped tests have no folder. Requires probes.execution_index: true to write status files.
exhaustive_vars (optional)
Variables to test exhaustively at each search point (for hybrid strategies).
max_core_hours (optional)
CPU core-hours budget. Overridable via --max-core-hours.
cores_expr (optional, default: “1”)
Jinja2 expression to compute cores per test (e.g., "{{ nodes * ppn }}").
estimated_time_seconds (optional)
Estimated time per test. Used for dry-run budget analysis.
parallel (optional, default: 1)
Maximum number of tests to run concurrently (thread pool). Overridable via --parallel N. Works with both local and slurm executors.
Planner-aware behavior:
  • Exhaustive / Random: Supports any degree of parallelism (tests are independent).
  • Bayesian: Always capped to 1 (the optimizer’s ask/tell cycle is strictly sequential). A warning is logged if a higher value is requested.
  • Adaptive: Parallelism is capped to the number of independent probes (one per swept-variable combination). Tests within a single probe remain sequential.
Ignored in single-allocation mode (slurm_options.allocation.mode: "single").
vars
Defines the parameter space (swept variables) and computed values (derived variables).
vars:
  # Swept variable (list mode)
  variable_name:
    type: string                # Required: "int" | "float" | "str" | "bool" | "list"
    sweep:
      mode: list
      values: [1, 2, 4, 8]
  # Swept variable (range mode)
  variable_name:
    type: int
    sweep:
      mode: range
      start: 8
      end: 32
      step: 8
  # Conditional variable (swept only when condition is true)
  variable_name:
    type: int
    sweep:
      mode: list
      values: [1, 2, 4]
    when: "other_var == true"   # Optional: condition expression
    default: 0                  # Required if 'when' is specified
  # Adaptive variable (probing search)
  variable_name:
    type: int
    adaptive:
      initial: 1000             # Starting value (required)
      factor: 2                 # Multiplicative step (one of factor/increment/step_expr)
      stop_when: "exit_code != 0"  # Stop condition (required)
      max_iterations: 10        # Safety limit (optional)
      direction: "ascending"    # "ascending" (default) or "descending"
  # Escalating variable (paired with an adaptive variable)
  variable_name:
    type: int
    escalate:
      values: [1, 4, 16]        # Tried in order when the adaptive probe stalls
  # Derived variable
  variable_name:
    type: int
    expr: "nodes * processes_per_node"
type (required)
Data type: int, float, str, bool, or list.
The list type is used for derived variables that hold arrays, enabling indexed access in templates. See Templating Guide for examples.
sweep (for swept variables)
Defines values to sweep. Creates executions via Cartesian product. Mutually exclusive with expr and adaptive.
mode: list takes an explicit values list. mode: range takes start, end, step (inclusive; start: 8, end: 32, step: 8 creates [8, 16, 24, 32]); step can be negative for descending ranges.
expr (for derived variables)
Expression to compute the variable. Mutually exclusive with sweep and adaptive.
Expression Examples
Python arithmetic:
vars:
  block_size_mb:
    type: int
    expr: "(volume_size_gb * 1024) // (nodes * processes_per_node)"
  total_processes:
    type: int
Jinja2 templates:
vars:
  summary_file:
    type: str
    expr: "{{ execution_dir }}/summary_{{ execution_id }}_{{ repetition }}.json"
  output_path:
    type: str
    expr: "{{ workdir }}/results/node_{{ nodes }}"
Available functions: min(), max(), abs(), round(), floor(), ceil(), int(), float()
Built-in variables (execution_id, repetition, repetitions, workdir, execution_dir, artifacts_dir, os_env, …) are available in expressions; see Standard Context Variables.
adaptive (for adaptive/probing variables)
Defines a variable that is explored by adaptive probing. Mutually exclusive with sweep and expr. Requires benchmark.search_method: "adaptive". Only one adaptive variable is allowed per config.
See Adaptive Variables for a full guide with examples.
Adaptive Configuration Fields
FieldRequiredDefaultDescription
initialYesStarting value
factorOne of threeMultiplicative step (next = previous * factor)
incrementOne of threeAdditive step (next = previous + increment)
step_exprOne of threeJinja2 expression for custom progression
stop_whenYesPython expression evaluated after each execution
max_iterationsNoNo limitMaximum number of values to test
directionNo"ascending""ascending" or "descending"
Escalate Configuration Fields
valuesYesOrdered values to escalate through when the adaptive probe would stop
An escalating variable turns an adaptive probe into a staircase search: instead of finishing the first time stop_when triggers, the escalating variable advances and the same adaptive value is retested. Requires an adaptive variable; at most one per config. See Staircase Search.
when (for conditional variables, optional)
Condition expression for conditional sweep. When true, the variable is swept normally; when false, it uses the default value. Only valid for swept variables. This eliminates redundant combinations where a variable is irrelevant given another variable’s value. See Execution Matrix Generation for how conditional variables shape the matrix.
default (required if when is specified)
Value to use when the when condition is false. Must be compatible with the variable’s type.
Conditional Variable Examples
Basic conditional:
vars:
  use_compression:
    type: bool
    sweep:
      mode: list
      values: [true, false]
  compression_level:
    type: int
    sweep:
      mode: list
      values: [1, 5, 9]
    when: "use_compression"    # Only sweep when use_compression is true
    default: 0                 # Use 0 when use_compression is false
Without when: 2 × 3 = 6 combinations With when: 3 (true) + 1 (false) = 4 combinations
Conditions can chain: a variable’s when may reference another conditional variable (e.g., when: "feature_mode != 'disabled'" where feature_mode itself has a when).
Available operators: ==, !=, <, >, <=, >=, and, or, not
Defines validation rules for parameter combinations.
constraints:
  - name: string              # Required: unique constraint identifier
    rule: string              # Required: Python expression returning bool
    violation_policy: string  # Optional: "skip" | "error" | "warn" (default: "skip")
    description: string       # Optional: human-readable explanation
name (required)
Unique identifier for this constraint.
rule (required)
Python expression evaluating to True (valid) or False (invalid).
Available context:
  • All variables defined in vars
  • os_env: System environment variables (dict) - e.g., os_env.get('MY_VAR', '')
  • Math functions: min, max, abs, round, floor, ceil, int, float
violation_policy (optional, default: “skip”)
  • skip: Filter out invalid combinations
  • error: Stop execution immediately
  • warn: Log warning but proceed
description (optional)
Human-readable explanation.
Examples
constraints:
  # Divisibility
  - name: "block_transfer_alignment"
    rule: "block_size % transfer_size == 0"
    violation_policy: "skip"
    description: "Block size must be a multiple of transfer size"
  # Resource limits
  - name: "max_processes"
    rule: "nodes * processes_per_node <= 256"
    violation_policy: "warn"
  # Environment variable requirement
  - name: "require_scratch_dir"
    rule: "os_env.get('SCRATCH', '') != ''"
    violation_policy: "error"
    description: "SCRATCH environment variable must be set"
command
Defines the benchmark command template and labels.
command:
  template: string              # Required: command template (Jinja2)
  labels:                       # Optional: user-defined labels
    key: value
template (required)
The benchmark command as a Jinja2 template.
command:
  template: >
    ior -w -b {{ block_size_mb }}mb -t 1mb
    -O summaryFile={{ summary_file }}
    -o {{ output_path }}/data.ior
labels (optional)
User-defined key-value labels stored with results. Appears as labels.* columns in output.
Note: metadata.* is reserved for IOPS internal fields (executor status, timing, errors).
command:
  labels:
    operation: "write"
    io_engine: "MPI-IO"
    access_pattern: "contiguous"
scripts
Defines execution scripts, submission commands, and result parsers.
scripts:
  - name: string                    # Required: script identifier
    script_template: |              # Required: script content (Jinja2)
      #!/bin/bash
      {{ command.template }}
    inputs:                         # Optional: input files generated before script runs
      - name: string                #   Required: logical id, referenced as {{ inputs.<name>.path }}
        path: string                #   Required: destination path on disk (Jinja2)
        template: |                 #   Inline content (Jinja2). Use EITHER template OR file.
        file: string                #   Path to external template file (alternative to `template`)
        mode: string                #   Optional octal string, e.g. "0644"
    post:                           # Optional: post-processing
      script: |
        #!/bin/bash
    parser:                         # Optional: result parser
      file: string                  #   Output file to parse
      metrics:                      #   Metrics to extract
        - name: string
      parser_script: |              #   Python parser function
        def parse(file_path: str):
            return {"metric": value}
name (required)
Script identifier. Used for file naming.
script_template (required)
Script content as Jinja2 template. Use {{ command.template }} to include the command.
scripts:
  - name: "ior"
    script_template: |
      #!/bin/bash
      #SBATCH --job-name=iops_{{ execution_id }}
      #SBATCH --output={{ execution_dir }}/stdout
      #SBATCH --nodes={{ nodes }}
      #SBATCH --ntasks-per-node={{ processes_per_node }}
      #SBATCH --time=01:00:00
      module load mpi ior
      mpirun {{ command.template }}
For local execution, omit the #SBATCH directives. See Writing Scripts for practical guidance and more examples.
inputs (optional)
Declarative input files generated before the script runs, for benchmarks that read parameters from a config file (or hostfile, manifest, etc.) instead of the command line.
Files are rendered with the same Jinja2 context as script_template and written at preparation time, alongside run_*.sh, so the exact input of every execution is on disk for inspection even when the script aborts before producing output.
scripts:
  - name: "ior"
    inputs:
      - name: ior_config
        path: "{{ execution_dir }}/ior.conf"
        template: |
          IOR START
            api = POSIX
            blockSize = {{ block_size_mb }}m
            transferSize = {{ transfer_size_kb }}k
            numTasks = {{ nodes * processes_per_node }}
          IOR STOP
      - name: hostfile
        file: "./templates/hostfile.j2"
        mode: "0644"
    script_template: |
      #!/bin/bash
      ior -f {{ inputs.ior_config.path }} \
          --hostfile {{ inputs.hostfile.path }}
Fields per entry:
FieldRequiredDescription
nameYesIdentifier used in {{ inputs.<name>.path }} references. Must be a valid Python identifier, unique within the script.
pathYesDestination path on disk, Jinja2-rendered (e.g. "{{ execution_dir }}/ior.conf").
templateOne ofInline content, rendered with the full execution context.
fileOne ofPath to an external template file (resolved relative to the YAML config, or as an absolute path). The file content replaces template at load time.
modeNoOctal string (e.g., "0644") applied with chmod after the file is written.
Context available in template and path:
  • All swept and derived variables ({{ nodes }}, {{ block_size_mb }}, …)
  • {{ execution_dir }}, {{ workdir }}, {{ execution_id }}, {{ repetition }}, {{ repetitions }}
  • {{ os_env.* }} for environment variables
  • {{ inputs.<other>.path }} to reference another input’s resolved path (within the same script)
{{ inputs.<name>.path }} also works in script_template, post.script, and the top-level command.template.
Rules:
  • Jinja2 syntax in template and path is validated at load time (alongside script_template).
  • The file is rewritten on every repetition, so each repetition_NNN folder gets its own copy.
post (optional)
Post-processing script executed after main script completes:
scripts:
  - name: "ior"
    script_template: |
    post:
      script: |
        #!/bin/bash
        echo "Job completed at $(date)"
        echo "Summary: {{ summary_file }}"
        ls -lh {{ execution_dir }}
parser (required)
Defines how to extract metrics from benchmark output:
scripts:
  - name: "ior"
    script_template: |
    parser:
      file: "{{ summary_file }}"
      metrics:
        - name: bwMiB
        - name: iops
      parser_script: |
        import json
            with open(file_path, "r") as f:
                data = json.load(f)
            results = data["tests"][0]["Results"][0]
            return {
                "bwMiB": float(results["bwMiB"]),
                "iops": float(results["OPs"])
Requirements:
  • Function must be named parse
  • Takes one argument: file_path (str)
  • Returns dict with metric names matching metrics list
See Writing Parsers for context globals and more examples.
output
Defines where and how to store execution results.
output:
  sink:
    type: string              # Required: "csv" | "parquet" | "sqlite"
    path: string              # Optional: output file path (Jinja2), has sensible defaults
    exclude:                  # Optional: fields to exclude from output
      - "benchmark.description"
    table: string             # Optional: table name for SQLite (default: "results")
type (required)
Output format: csv, parquet, or sqlite.
path (optional)
Output file path. Can use Jinja2 templates.
Defaults by type:
  • csv → {{ workdir }}/results.csv
  • parquet → {{ workdir }}/results.parquet
  • sqlite → {{ workdir }}/results.db
exclude (optional)
Exclude specific fields from output using dot notation. Wildcards are supported.
PrefixFields
benchmark.*name, description
execution.*repetitions, workdir, execution_dir (note: execution_id and repetition are protected)
vars.*All variable names
labels.*All user-defined labels from command.labels
metadata.*IOPS internal fields (executor_status, start, end, error, jobid)
metrics.*All parser metric names
Protected fields: execution.execution_id and execution.repetition cannot be excluded as they are required for identifying results.
table (optional, SQLite only)
Table name (default: “results”).
Enables HTML report generation with interactive plots. Disabled by default.
reporting:
  enabled: boolean              # Optional: enable auto-generation (default: false)
  output_dir: path              # Optional: report output directory (default: workdir)
  output_filename: string       # Optional: report filename (default: "analysis_report.html")
  theme:                        # Optional: theme configuration
    style: string               #   Plotly theme: "plotly_white" (default), "plotly",
                                #   "plotly_dark", "ggplot2", "seaborn", "simple_white"
    colors: list                #   Custom color palette (hex codes)
    font_family: string         #   Font family (e.g., "Arial, sans-serif")
  sections:                     # Optional: section visibility
    test_summary: boolean       #   Execution statistics (default: true)
    best_results: boolean       #   Top N configurations (default: true)
    variable_impact: boolean    #   Variance-based importance (default: true)
    parallel_coordinates: boolean #   Multi-dimensional visualization (default: true)
    bayesian_evolution: boolean #   Optimization progress, Bayesian only (default: true)
    bayesian_parameter_evolution: boolean #   Parameter exploration (default: false)
    resource_sampling: boolean  #   Resource metrics summary table (default: true)
    custom_plots: boolean       #   User-defined plots (default: true)
    gallery: boolean            #   Per-execution image gallery (default: true; auto-enabled when images exist)
    versions: boolean           #   Software versions table (default: true; auto-enabled when probe data exists)
  gallery:                      # Optional: per-execution image gallery
    enabled: boolean            #   Enable the gallery section (default: false)
    folder: string              #   Convention folder per execution dir (default: "images")
    sources: list               #   OPTIONAL: Jinja2-templated paths resolved per execution
    pattern: string             #   Glob for convention folder (default: "*.png")
    max_width: integer          #   OPTIONAL: downscale cap in pixels (needs [gallery] extra)
    caption_vars: list          #   OPTIONAL: variable names shown under each card
    title: string               #   Gallery section heading (default: "Image Gallery")
  best_results:                 # Optional: best results configuration
    top_n: integer              #   Number of top configs (default: 5)
    show_command: boolean       #   Include rendered command (default: true)
    min_samples: integer        #   Minimum repetitions required (default: 1)
  metrics:                      # Optional: per-metric plot definitions
    metric_name:                #   Benchmark metrics (from parsers) or resource
      plots:                    #   sampling metrics (cpu_avg_pct, gpu_energy_j, etc.)
        - type: string
          x_var: string
  default_plots:                # Optional: fallback plots
    - type: string
      per_variable: boolean
  plot_defaults:                # Optional: default sizing
    height: integer             #   (default: 500)
    width: integer              #   (default: null = auto)
    margin:                     #   (default: null = Plotly defaults)
      l: integer
      r: integer
      t: integer
      b: integer
Reports can also be generated manually with iops report, regardless of enabled.
metrics (optional)
Define custom plots per metric. Both benchmark metrics (from parser scripts) and resource sampling metrics (from probes) can be used:
reporting:
  metrics:
    # Benchmark metric (from parser)
    bwMiB:
      plots:
        - type: "line"
          x_var: "block_size_mb"
          group_by: "nodes"
          title: "Bandwidth vs Block Size"
        - type: "heatmap"
          x_var: "nodes"
          y_var: "processes_per_node"
          colorscale: "Viridis"
    # Resource sampling metric (from gpu_sampling probe)
    gpu_energy_j:
      plots:
        - type: "bar"
          x_var: "nodes"
          title: "GPU Energy Consumption"
Available resource metrics are listed in the generated report_config.yaml. See Custom Reports for the full list.
Plot types: bar, line, scatter, heatmap, box, violin, surface_3d, parallel_coordinates, execution_scatter, coverage_heatmap
Plot TypeRequiredKey Options
barx_varshow_error_bars
linex_vargroup_by
scatterx_vary_var, color_by
heatmapx_var, y_varcolorscale
boxx_varshow_outliers
coverage_heatmaprow_vars, col_varaggregation, sort_rows_by
default_plots (optional)
Fallback plots for metrics without custom configuration:
reporting:
  default_plots:
    - type: "execution_scatter"
    - type: "bar"
      per_variable: true
      show_error_bars: true
hooks (optional)
Commands that IOPS runs on the host running it when run events happen (start, progress, failures, finish). Hooks never affect the benchmark. See the Hooks guide for details and examples.
hooks:
  - name: halfway_mail
    event: progress                 # start, progress, failures, consecutive_failures, finish
    at: ["25%", "50%"]              # One-shot thresholds: integer count or "N%" string
    every: 100                      # Repeating threshold (alternative or addition to at)
    command: >                      # Jinja2 template, run with bash
      echo {{ message | quote }} |
      mail -s "IOPS {{ benchmark.name }}" me@example.org
    timeout: 60                     # Seconds before the command is killed
name (optional, default: hook_<index>)
Unique name of the hook, used in logs and by iops hooks test --hook.
event (required)
One of start, progress, failures, consecutive_failures, finish. The key is event, not on, because YAML reads a bare on as a boolean.
command (required)
Shell command rendered with Jinja2 (strict mode) against the run context: event, progress, run, benchmark.name, workdir, report_path, hostname, os_env, and message. Benchmark variables are not available. The quote filter shell-quotes a value. The same values are exported as IOPS_* environment variables.
at / every (required for progress, failures, consecutive_failures)
at is a threshold or list of thresholds, each fired once. every is a repeating threshold. A threshold is an integer (a count of attempts, that is, executions times repetitions) or a string ending in %. consecutive_failures and failures with every accept counts only. Not allowed for start and finish.
when (optional, finish only)
Outcomes that fire the hook: completed, interrupted, budget_exceeded, fail_fast, crashed. Default: all.
min_tests (optional, default: 10)
For percentage thresholds on failures: number of tests that must have run before the failure rate is evaluated. Lowered to the number of runnable tests on small runs.
timeout (optional, default: 60)
Seconds before the command and its child processes are killed.
machines (optional)
Per-machine configuration overrides. Select at runtime with --machine NAME or IOPS_MACHINE env var.
machines:
  machine_name:       # Arbitrary machine identifier
    benchmark: {}     # Optional: benchmark overrides
    vars: {}          # Optional: variable overrides
    command: {}       # Optional: command overrides
    scripts: []       # Optional: script overrides
    output: {}        # Optional: output overrides
    constraints: []   # Optional: constraint overrides
    reporting: {}     # Optional: reporting overrides
    hooks: []         # Optional: hook overrides (merged by name)
Each machine entry can override any combination of the standard top-level sections. Overrides are deep-merged into the base configuration: only what you specify is changed.
See the Machine Overrides Guide for merge rules, examples, and best practices.
